ERROR: UFFParser: Validator error: my_trt_op_0: Unsupported operation _TRTEngineOp
I am working on optimizing my SSD_mobilenetV2 models(Tensorflow/models/research/object_detection) with TensorRT .I have tried to optimize my original tensorFlow frozen model to run on TensorRT using create_inference_graph(),I get TensorRT optimized graph (FP16).But when I convert the TensorRT optimized graph (FP16) to uff, The conversion from the frozen graph to UFF file is successful, however, when running sample_uff_ssd.cpp, erros occur:
Begin parsing model…
Can you tell me what the problem is?
My code is as below:
trt_graph = trt.create_inference_graph(
    input_graph_def=frozen_graph,
    outputs=output_names,
    max_batch_size=1,
    max_workspace_size_bytes=1 << 25,
    precision_mode='FP16',
    minimum_segment_size=50
convert-to-uff --input-file frozen_inference_graph_float16.pb -O NMS -p config_mobilenet.py
the config file as follows:
import graphsurgeon as gs
import tensorflow as tf
Input = gs.create_node("Input",
    op="Placeholder",
    dtype=tf.float32,
    shape=[1, 3, 300, 300])
PriorBox = gs.create_plugin_node(name="GridAnchor", op="GridAnchor_TRT",
    numLayers=6,
    minSize=0.2,
    maxSize=0.95,
    aspectRatios=[1.0, 2.0, 0.5, 3.0, 0.33],
    variance=[0.1,0.1,0.2,0.2],
    featureMapShapes=[19, 10, 5, 3, 2, 1])
NMS = gs.create_plugin_node(name="NMS", op="NMS_TRT",
    shareLocation=1,
    varianceEncodedInTarget=0,
    backgroundLabelId=0,
    confidenceThreshold=1e-8,
    nmsThreshold=0.5,
    topK=100,
    keepTopK=100,
    numClasses=5,
    inputOrder=[0, 2, 1],
    confSigmoid=1,
    isNormalized=1,
    scoreConverter="SIGMOID")
concat_priorbox = gs.create_node(name="concat_priorbox", op="ConcatV2", dtype=tf.float32, axis=2)
concat_box_loc = gs.create_plugin_node("concat_box_loc", op="FlattenConcat_TRT", dtype=tf.float32, axis=1, ignoreBatch=0)
concat_box_conf = gs.create_plugin_node("concat_box_conf", op="FlattenConcat_TRT", dtype=tf.float32, axis=1, ignoreBatch=0)
namespace_plugin_map = {
    "MultipleGridAnchorGenerator": PriorBox,
    "Postprocessor": NMS,
    "Preprocessor": Input,
    "ToFloat": Input,
    "image_tensor": Input,
    "MultipleGridAnchorGenerator/Concatenate": concat_priorbox,
    "concat": concat_box_loc,
    "concat_1": concat_box_conf
def preprocess(dynamic_graph):
    # Now create a new graph by collapsing namespaces
    dynamic_graph.collapse_namespaces(namespace_plugin_map)
    # Remove the outputs, so we just have a single output node (NMS).
    dynamic_graph.remove(dynamic_graph.graph_outputs, remove_exclusive_dependencies=False)
You can find my model here:
