ERROR: Unable to find display on any available system when using wayland and eglstreams
I can’t seem to open the nvidia settings when under wayland and using eglstreams, it just gives the error “ERROR: Unable to find display on any available system” how do I fix this?
Also is 30 bit precision not supported under wayland? If it is how do I enable it under wayland?
nvidia-settings is an X application which then uses xwayland which doesn’t work yet with the nvidia driver.
Thanks, do you know if the nvidia driver supports 10 bit per color using the wayland backend?
On xorg it supports but needs to be specified on a xorg.conf file…
IDK but from the looks of it, it should support that. At least I didn’t find anything that tells about a limitation of any kind.
Under wayland it doesn’t read the xorg.cong 10 bit configuration that is required to be set under x11 for it to be enabled.
So if how do I configure Nvidia if the configuration program doesn’t work with my systems graphics system? I’m using Fedora 34 and I’ve attached the debug file…
nvidia-bug-report.log.gz (1.1 MB)
