Hi there, I have a NVIDIA Jetson Xavier NX Developer Kit - Jetpack 5.1.1 [L4T 35.3.1]
Am following the steps to upgrade to 5.1.2, 1.3 section from here
https://docs.nvidia.com/jetson/jetpack/install-jetpack/index.html#package-management-tool
~$ sudo dpkg --configure nvidia-l4t-kernel
Setting up nvidia-l4t-kernel (5.10.120-tegra-35.4.1-20230801124926) …
Using the existing boot entry ‘primary’
3668-100—1–jetson-xavier-nx-devkit-
Info. Active boot storage: mmcblk0
Info. Legacy mode: false
TNSPEC 3668-200-0000-J.0-1-2-jetson-xavier-nx-devkit-
COMPATIBLE_SPEC 3668-100—1–jetson-xavier-nx-devkit-
TEGRA_LEGACY_UPDATE false
TEGRA_BOOT_STORAGE mmcblk0
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x19
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Info: Write TegraPlatformCompatSpec with 3668-100—1–jetson-xavier-nx-devkit-.
Starting kernel post-install procedure.
ERROR. Failed to get number of rootfs slots. Exiting…
dpkg: error processing package nvidia-l4t-kernel (–configure):
installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
nvidia-l4t-kernel
not sure how to continue? I appreciate any guidance on the issue, thanks
