The C++20 code below fails to compile with nvc++ 22.2. It seems to concern the use of the requires clause, which distinguishes the two conversion functions. MFE code is shown below:
template <bool B>
struct Foo {
operator unsigned() const requires(B) { return B; }
operator unsigned() const requires(!B) { return B; }
int main(int argc, char *argv[])
Foo<true> f1;
Foo<false> f2;
unsigned i1 = f1;
unsigned i2 = f2;
return (i1==1 && i2==0) ? 0 : -1;
The invocation and error message are:
$ nvc++ -std=c++20 requires.cpp
"requires.cpp", line 12: error: more than one conversion function from "Foo<true>" to "unsigned int" applies:
function "Foo<B>::operator unsigned int() const [with B=true]" (declared at line 3)
function "Foo<B>::operator unsigned int() const [with B=true]" (declared at line 4)
unsigned i1 = f1;
"requires.cpp", line 13: error: more than one conversion function from "Foo<false>" to "unsigned int" applies:
function "Foo<B>::operator unsigned int() const [with B=false]" (declared at line 3)
function "Foo<B>::operator unsigned int() const [with B=false]" (declared at line 4)
unsigned i2 = f2;
2 errors detected in the compilation of "requires.cpp".
Best regards,
Paul
