Error using nvdspreprocess resize using NvBufSurfTransformInter_Algo2 in object mode
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 530.30
• Issue Type( questions, new requirements, bugs) error
Hi, I am using the nvdspreprocess plugin in object mode after pgie, and I can use it for resizing using nearest and bilinear algorithms. With NvBufSurfTransformInter_Algo2 is am facing error.
CUDA error at nvbufsurftransform.cpp:2817 code=23(NPP_RESIZE_FACTOR_ERROR) “nppiResizeSqrPixel_8u_C1R (src_ptr + src_offset, nppSrcSize, jsrc_pitch, jnppSrcROI, intermediate_buffer+dst_offset, jdst_pitch, jnppDstROI, scale_x, scale_y, jdx, jdy, nppInterFlag)”
0:01:09.776572590 1 0x4dfe980 ERROR nvdsspreprocess gstnvdsspreprocess.cpp:1230:batch_transformation: NvBufSurfTransform failed with error -2
why do you need NvBufSurfTransformInter_Algo2 in your code? it is only used to donwnscle.
/** Specifies GPU-Super, VIC-10 Tap interpolation. */
NvBufSurfTransformInter_Algo2,
It has been working well for our use cases, for most of our model’s final inference accuracies are close to their pytorch variant with Algo2. Any issue in using Algo2 for nvdspreprocess in object mode?
NvBufSurfTransformInter_Algo2 only supports donwnscle, does not support upscale.
