Error using Ouster2-128 with Drivesoftware 10.0
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
I am trying to run an ouster-os2 with the lidar replay sample. As per some of the other posts I have downloaded the ouster plug in and am trying to run it as a custom sensor. I execute the following command:
./sample_lidar_replay --protocol=lidar.custom --params=decoder-path=/home/nvidia/ouster-nvidia-driveworks_plugin_v1.0.3/dist/arm/lib/libouster_lidar_plugin_arm.so,device=CUSTOM_EX,ip=192.168.1.41,dip=192.168.1.201,lidar_port=56503,imu_port=60604,data=/home/nvidia/lidar_data/,session_id=test_run
After executing I get an error stating: Driveworks exception thrown: DW_SAL_CANNOT_CREATE_SENSOR: LidarCustom: could not open shared library libdriveworks.so.3 cannot open shared object file: No such file or directory
Is there a workaround for this?
I assume you’re using the specific model listed on the ecosystem page. Please contact Ouster for the software support accordingly.
