Hi guys, I am trying to write a program to perform a sum of matrices using CUDA Streams but I’m getting a couple of errors when I try to compile:
First of all, I have the following error:
./matrixSum_kernel.cu(59): error: expected a “)”
and I’m pretty sure I have closed all the brackets
and the second one is:
matrixSum.cu(151): error: too many arguments in function call
but you can check in the code that the number of arguments is right
This is the definition of streams in the file matrixSum.cu
[codebox]#define NUM_STREAMS 2
128
129 int i;
130 cudaStream_t stream[NUM_STREAMS];
131
132 for (i=0; i<NUM_STREAMS ; ++i)
133 cudaStreamCreate(&stream[i]);
134
135 for (i=0 ; i<NUM_STREAMS ; ++i) {
136 cudaMemcpyAsync(d_A + iwABLOCK_SIZE, h_A + iwABLOCK_SIZE,wABLOCK_SIZEsizeof(float),cudaMemcpyHostTo
Device, stream[i]);
137 cudaMemcpyAsync(d_B + iwABLOCK_SIZE, h_B + iwABLOCK_SIZE,wABLOCK_SIZEsizeof(float),cudaMemcpyHostTo
Device, stream[i]);
138 }
139
140 // create and start timer
141 unsigned int timer = 0;
142 CUT_SAFE_CALL(cutCreateTimer(&timer));
143 CUT_SAFE_CALL(cutStartTimer(timer));
144
145 // setup execution parameters
146 dim3 threads(BLOCK_SIZE, BLOCK_SIZE);
147 dim3 grid(wA / threads.x, wA / threads.y);
148
149 for (i=0 ; i<NUM_STREAMS ; ++i) {
150 // execute the kernel
151 matrixSum<<<grid, threads ,0, *stream>>>(d_C, d_A, d_B, wA, wA);
152
153 // check if kernel execution generated and error
154 CUT_CHECK_ERROR(“Kernel execution failed”);
// stop and destroy timer
158 CUT_SAFE_CALL(cutStopTimer(timer));
161 printf(“Processing time: %f (ms) \n”, cutGetTimerValue(timer));
163 CUT_SAFE_CALL(cutDeleteTimer(timer));
164
165
166 for (i=0 ; i<NUM_STREAMS ; ++i)
167 cudaMemcpyAsync(h_C +iBLOCK_SIZE, d_C + iBLOCK_SIZE, wABLOCK_SIZEsizeof(float), cudaMemcpyDeviceToHost, stream[i]);
168
169 cudaThreadSynchronize();
155 }
[/codebox]
and this is the definition of the kernel in the file matrixSum_kernel.cu
[codebox]global void
59 matrixSum( float* C, float* A, float* B, int wA, int wB)
60 {[/codebox]
I would appreciate if you could offer any help to solve this problems as I don’t know if they come from the Stream definition or there’s a mistake I’m missing.
