I am using an USB-Network-Adapter to have a second Ethernet connection on Jetson AGX Xavier.
When I am connecting the network adapter (USB Type A to RJ45) with the USB-C/USB-A adapter (contained in the developer kit) everthing works fine (see fist image).
But actually I don´t want to use the USB-C/USB-A adapter. Therefore I plugged in the ethernet adapter directly into the USB-A port at the back of the Xavier. The device cannot be used now, dmesg shows the following error:
Does anyone have an advice how to fix this?
Thank you very much!
