Hello, I have an RTX 3050TI Laptop GPU. Unfortunately, I cannot play some games, for example, while playing a game, I get a fatal error when I quit the game and then when I shut down or restart my computer, I even get a blue screen named “VIDEO_DXGKRNL_FATAL_ERROR” after a few delays. I scanned it on WinDbg and it shows the " nvlddmkm.sys" problem. If I format my computer or uninstall the GPU Driver via DDU, it still doesn’t work. When I entered the Control Panel before the blue screen, I realized that it did not show the 3D image with the NVIDIA logo there. I guess it is like blowing a fuse to prevent any damage to itself. Is there any solution to this? My resolution is 1920 x 1080 scaling 125%
On the plus side, I don’t get any errors from CAD programs like AutoCAD & Solidworks. I wonder if they don’t get any errors because they are in windowed mode. If I recall, I didn’t get any errors when I played one of the crashing games in windowed mode. So, is there a problem with full screen?
I analyzed it with the WinDbg program and this is the full result:
Bugcheck analysis *
VIDEO_DXGKRNL_FATAL_ERROR (113)
The dxgkrnl has detected that a violation has occurred. This resulted.
İn a condition that dxgkrnl can no longer progress. By crashing, dxgkrnl.
İs attempting to get enough information into the minidump such that somebody.
Can pinpoint the crash cause. Any other values after parameter 1 must be.
İndividually examined according to the subtype.
Arguments:
Arg1: 0000000000000019, the subtype of the bugcheck:
Arg2: 0000000000000002.
Arg3: 00000000000010’de.
Arg4: 00000000000025A0.
Debugging details:
I have the same issue, with RTX 3050 laptop. The same behaviour with some games and during watching Netflix. Moreover, if I leave the laptop connected to power and let it sleep for around one hour, the screen gets black and the fans start running with maximum speed and the only solution is to press power button for 10 seconds… I am trying to fix it for two years, no solution so far. Any ideas are more than welcome!
Windows 11 Pro 24H2 (but the same issue exists since 22H2).
AMD Ryzen 9 6900 HX
32 GB RAM (but with 16 GB had the same problem)
