I downloaded and installed the Jetpack 3.3 SDK onto my x64 Ubuntu Linux box.
I wanted to build the samples for aarch64 so that I could run them on my Jetson TX2.
I set LD_LIBRARY_PATH approrpriately:
export LD_LIBRARY_PATH=/usr/local/cuda-9.0/targets/aarch64-linux/lib
I then navigated to the samples folder and entered the following command to build the samples:
SMS=53 EXTRA_LDFLAGS=–unresolved-symbols=ignore-in-shared-libs TARGET_ARCH=aarch64 make
But the build failed:
aarch64-linux-gnu-g++ -o simpleTemplates_nvrtc simpleTemplates.o -lcuda -lnvrtc
/usr/lib/gcc-cross/aarch64-linux-gnu/5/…/…/…/…/aarch64-linux-gnu/bin/ld: cannot find -lcuda
/usr/lib/gcc-cross/aarch64-linux-gnu/5/…/…/…/…/aarch64-linux-gnu/bin/ld: cannot find -lnvrtc
collect2: error: ld returned 1 exit status
Makefile:323: recipe for target ‘simpleTemplates_nvrtc’ failed
make[1]: *** [simpleTemplates_nvrtc] Error 1
make[1]: Leaving directory ‘/usr/local/cuda-9.0/samples/0_Simple/simpleTemplates_nvrtc’
Makefile:52: recipe for target ‘0_Simple/simpleTemplates_nvrtc/Makefile.ph_build’ failed
make: *** [0_Simple/simpleTemplates_nvrtc/Makefile.ph_build] Error 2
Can someone help me figure out why?
