I am new to using ubuntu so this may be a simple question answered, However I was running the linked code for installing the NGC but after running the first few lines of code provided, running nvidia-smi came up with nothing.
So i tried going through the steps once more and i see an error that says:
0 upgraded, 19 newly installed, 0 to remove and 255 not upgraded.
Need to get 4,217 kB/86.4 MB of archives.
After this operation, 406 MB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
nvidia-387 nvidia-387-dev libcuda1-387 nvidia-modprobe libxnvctrl0
nvidia-settings nvidia-opencl-icd-387 cuda-drivers
E: There were unauthenticated packages and -y was used without --allow-unauthenticated
:~$ Read more at: http://docs.nvidia.com/ngc/ngc-titan-setup-guide/index.html#ixzz5121EAGG5
No command ‘Read’ found, did you mean:
Command ‘head’ from package ‘coreutils’ (main)
Read: command not found
I am not sure how to proceed
