Hi there,
I would like to change the activation function for my physics-based model (cylinder example). I have used the method described in the manual and used the correct import I found in this forum.
However, I receive the following error:
Error executing job with overrides: []
File "/software/modulus/22.09/lib/python3.8/site-packages/modulus-22.9-py3.8.egg/modulus/hydra/utils.py", line 200, in instantiate_arch
model, param = model_arch.from_config(model_cfg)
File "/software/modulus/22.09/lib/python3.8/site-packages/modulus-22.9-py3.8.egg/modulus/models/arch.py", line 500, in from_config
cfg["activation_fn"] = Activation[cfg["activation_fn"]]
File "/software/modulus/22.09/lib/python3.8/site-packages/modulus-22.9-py3.8.egg/modulus/models/layers/activation.py", line 16, in __getitem__
return super().__getitem__(name.upper())
AttributeError: 'Activation' object has no attribute 'upper'
The above exception was the direct cause of the following exception:
File "cylinder_2d.py", line 85, in run
flow_net = instantiate_arch(
File "/software/modulus/22.09/lib/python3.8/site-packages/modulus-22.9-py3.8.egg/modulus/hydra/utils.py", line 210, in instantiate_arch
raise Exception(fail) from e
Exception: Failed to initialize architecture.
{'input_keys': [x, y], 'output_keys': [u, v, p], 'detach_keys': [???], 'scaling': None, 'layer_size': 512, 'nr_layers': 6, 'skip_connections': False, 'activation_fn': <Activation.SILU: 9>, 'adaptive_activations': False, 'weight_norm': True}
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
ERROR:torch.distributed.elastic.multiprocessing.api:failed (exitcode: 1) local_rank: 0 (pid: 121742) of binary: /software/modulus/22.09/bin/python3.8
File "/software/modulus/22.09/bin/torchrun", line 8, in <module>
sys.exit(main())
File "/software/modulus/22.09/lib/python3.8/site-packages/torch/distributed/elastic/multiprocessing/errors/__init__.py", line 346, in wrapper
return f(*args, **kwargs)
File "/software/modulus/22.09/lib/python3.8/site-packages/torch/distributed/run.py", line 762, in main
run(args)
File "/software/modulus/22.09/lib/python3.8/site-packages/torch/distributed/run.py", line 753, in run
elastic_launch(
File "/software/modulus/22.09/lib/python3.8/site-packages/torch/distributed/launcher/api.py", line 132, in __call__
return launch_agent(self._config, self._entrypoint, list(args))
File "/software/modulus/22.09/lib/python3.8/site-packages/torch/distributed/launcher/api.py", line 246, in launch_agent
raise ChildFailedError(
torch.distributed.elastic.multiprocessing.errors.ChildFailedError:
How can I fix this? It happens for different activation functions.
Many thanks in advance.
