I’m relatively new to Isaac Sim and Isaac Lab and am trying to change the terrain for the [Isaac-Velocity-Rough-G1-v0] environment for a custom terrain. But I keep encountering errors I didn’t encounter when running on Windows. Detailed information can be found below.
Isaac Sim Version
4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Isaac Lab Version (if applicable)
1.2
1.1
1.0
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model:
- Driver Version:
Topic Description
Detailed Description
I’m trying to run the [Isaac-Velocity-Rough-G1-v0] on a custom terrain. So to do this, I edited the G1RoughEnvCfg class by adding in self.scene.terrain.terrain_type, self.scene.terrain.usd_path and self.scene.terrain.terrain_generator as follows.
@configclass
class G1RoughEnvCfg(LocomotionVelocityRoughEnvCfg):
rewards: G1Rewards = G1Rewards()
terminations: TerminationsCfg = TerminationsCfg()
def __post_init__(self):
# post init of parent
super().__post_init__()
# Scene
self.scene.robot = G1_MINIMAL_CFG.replace(prim_path="{ENV_REGEX_NS}/Robot")
self.scene.height_scanner.prim_path = "{ENV_REGEX_NS}/Robot/torso_link"
self.scene.terrain.terrain_type = "usd"
self.scene.terrain.terrain_generator = None
self.scene.terrain.usd_path = "/home/__/Documents/Omniverse/USD_Files/custom_terrain.usd"
# Randomization
self.events.push_robot = None
self.events.add_base_mass = None
self.events.reset_robot_joints.params["position_range"] = (1.0, 1.0)
self.events.base_external_force_torque.params["asset_cfg"].body_names = ["torso_link"]
self.events.reset_base.params = {
"pose_range": {"x": (-0.5, 0.5), "y": (-0.5, 0.5), "yaw": (-3.14, 3.14)},
"velocity_range": {
"x": (0.0, 0.0),
"y": (0.0, 0.0),
"z": (0.0, 0.0),
"roll": (0.0, 0.0),
"pitch": (0.0, 0.0),
"yaw": (0.0, 0.0),
# Rewards
self.rewards.lin_vel_z_l2.weight = 0.0
self.rewards.undesired_contacts = None
self.rewards.flat_orientation_l2.weight = -1.0
self.rewards.action_rate_l2.weight = -0.005
self.rewards.dof_acc_l2.weight = -1.25e-7
self.rewards.dof_acc_l2.params["asset_cfg"] = SceneEntityCfg(
"robot", joint_names=[".*_hip_.*", ".*_knee_joint"]
self.rewards.dof_torques_l2.weight = -1.5e-7
self.rewards.dof_torques_l2.params["asset_cfg"] = SceneEntityCfg(
"robot", joint_names=[".*_hip_.*", ".*_knee_joint", ".*_ankle_.*"]
# Commands
self.commands.base_velocity.ranges.lin_vel_x = (0.0, 1.0)
self.commands.base_velocity.ranges.lin_vel_y = (-0.0, 0.0)
self.commands.base_velocity.ranges.ang_vel_z = (-1.0, 1.0)
Error Messages
Error executing job with overrides: []
File "/home/__/IsaacLab/source/extensions/omni.isaac.lab_tasks/omni/isaac/lab_tasks/utils/hydra.py", line 91, in hydra_main
func(env_cfg, agent_cfg, *args, **kwargs)
File "/home/__/IsaacLab/source/standalone/workflows/rsl_rl/train.py", line 101, in main
env = gym.make(args_cli.task, cfg=env_cfg, render_mode="rgb_array" if args_cli.video else None)
File "/home/__/IsaacLab/_isaac_sim/kit/python/lib/python3.10/site-packages/gymnasium/envs/registration.py", line 802, in make
env = env_creator(**env_spec_kwargs)
File "/home/__/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/envs/manager_based_rl_env.py", line 75, in __init__
super().__init__(cfg=cfg)
File "/home/__/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/envs/manager_based_env.py", line 116, in __init__
self.scene = InteractiveScene(self.cfg.scene)
File "/home/__/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/scene/interactive_scene.py", line 145, in __init__
self._add_entities_from_cfg()
File "/home/__/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/scene/interactive_scene.py", line 461, in _add_entities_from_cfg
self._terrain = asset_cfg.class_type(asset_cfg)
File "/home/__/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/terrains/terrain_importer.py", line 99, in __init__
self.import_usd("terrain", self.cfg.usd_path)
File "/home/__/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/terrains/terrain_importer.py", line 272, in import_usd
faces = np.asarray(mesh_prim.GetFaceVertexIndicesAttr().Get()).reshape(-1, 3)
ValueError: cannot reshape array of size 4 into shape (3)
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
2024-12-30 05:21:49 [16,791ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Annotators' for removal
2024-12-30 05:21:49 [16,791ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Core' for removal
2024-12-30 05:21:49 [16,886ms] [Warning] [carb] Recursive unloadAllPlugins() detected!
There was an error running python
Additional Context
When attempting a similar thing on a Windows computer running Isaac Sim 4.1 and Isaac Lab 1.1 this error didn’t occur and it was possible to use a custom terrain.
I’m wondering if the issue is related to the Isaac Lab version? However, I am unsure how to update my Isaac Lab version. Do I need to delete my current Isaac Lab install and re-install the version 1.3?
Thanks in advance for your help!
