we are trying to compile ems_usb.c from http://lxr.free-electrons.com/source/drivers/net/can/usb/ but i get the following error: gcc: error: unrecognized command line option ‘-mgeneral-regs-only’. The goal is to use the driver together with this CAN/USB interface http://ems-wuensche.com/product/datasheet/html/can-usb-adapter-converter-interface-cpcusb.html.
We think the error occurs because we are trying to compile with a 32 bit compiler while the kernel is 64 bit. We have read the following thread https://devtalk.nvidia.com/default/topic/906942/failed-to-compile-kernel-module-gcc-cannot-recognize-aarch64-option-mgeneral-regs-only-/ and made a quick try on cross-compiling but do to lack of experience and time(internship) it is probably not an option.
Has anyone else out there solved the problem? Maybe NVIDIA crew has already solved the problem? :)
