Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
I’m receiving the following error when I reach step 8 (compile OOT modules) following this documentation:
make -f /drive/drive-linux/kernel/source/oss_src/kernel/scripts/Makefile.build obj=/tmp/nv-oot/drivers/platform/tegra/uncore_pmu
need-builtin=
need-modorder=1
/drive/toolchains/aarch64–glibc–stable-2022.03-1/bin/aarch64-buildroot-linux-gnu-gcc -Wp,-MMD,/tmp/nv-oot/drivers/platform/tegra/.mc-hwpm.o.d -nostdinc -isystem /drive/toolchains/aarch64–glibc–stable-2022.03-1/bin/…/lib/gcc/aarch64-buildroot-linux-gnu/9.3.0/include -I/drive/drive-linux/kernel/source/oss_src/kernel/arch/arm64/include -I./arch/arm64/include/generated -I/drive/drive-linux/kernel/source/oss_src/kernel/include -I./include -I/drive/drive-linux/kernel/source/oss_src/kernel/arch/arm64/include/uapi -I./arch/arm64/include/generated/uapi -I/drive/drive-linux/kernel/source/oss_src/kernel/include/uapi -I./include/generated/uapi -include /drive/drive-linux/kernel/source/oss_src/kernel/include/linux/compiler-version.h -include /drive/drive-linux/kernel/source/oss_src/kernel/include/linux/kconfig.h -I/drive/drive-linux/kernel/source/oss_src/kernel/ubuntu/include -I/tmp/nv-oot/include -I/tmp/nv-oot/include -I/tmp/nv-oot/drivers/gpu/host1x/hw/ -I/tmp/nv-oot/drivers/video/tegra/host/ -I/tmp/nv-oot/drivers/gpu/host1x/include -I/include -I/tmp/nv-oot -include /drive/drive-linux/kernel/source/oss_src/kernel/include/linux/compiler_types.h -D__KERNEL__ -mlittle-endian -DKASAN_SHADOW_SCALE_SHIFT= -fmacro-prefix-map=/drive/drive-linux/kernel/source/oss_src/kernel/= -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Werror=return-type -Wno-format-security -std=gnu89 -mgeneral-regs-only -DCONFIG_CC_HAS_K_CONSTRAINT=1 -Wno-psabi -mabi=lp64 -fno-asynchronous-unwind-tables -fno-unwind-tables -mbranch-protection=pac-ret+leaf -Wa,-march=armv8.5-a -DARM64_ASM_ARCH=‘“armv8.5-a”’ -DKASAN_SHADOW_SCALE_SHIFT= -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-address-of-packed-member -O2 --param=allow-store-data-races=0 -Wframe-larger-than=2048 -fstack-protector-strong -Wimplicit-fallthrough=5 -Wno-main -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-stack-clash-protection -g -fno-var-tracking -femit-struct-debug-baseonly -pg -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -Wno-stringop-truncation -Wno-array-bounds -Wno-stringop-overflow -Wno-restrict -Wno-maybe-uninitialized -Wno-alloc-size-larger-than -fno-strict-overflow -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -Wno-packed-not-aligned -mstack-protector-guard=sysreg -mstack-protector-guard-reg=sp_el0 -mstack-protector-guard-offset=1344 -DMODULE -DKBUILD_BASENAME=‘“mc_hwpm”’ -DKBUILD_MODNAME=‘“mc_hwpm”’ -D__KBUILD_MODNAME=kmod_mc_hwpm -c -o /tmp/nv-oot/drivers/platform/tegra/mc-hwpm.o /tmp/nv-oot/drivers/platform/tegra/mc-hwpm.c
/tmp/nv-oot/drivers/video/tegra/host/nvdla/nvdla.c:24:10: fatal error: uapi/linux/tegra-soc-hwpm-uapi.h: No such file or directory
24 | include <uapi/linux/tegra-soc-hwpm-uapi.h>
That file is only found in:
/drive/drive-linux/kernel/source/oss_src/hwpm/include/uapi/linux/tegra-soc-hwpm-uapi.h
/drive/drive-linux/kernel/source/oss_src/nvidia/include/uapi/linux/tegra-soc-hwpm-uapi.h
And neither of the parent directories are in the -I lists during compilation.
