When I compile my pgf90 program to get outputfile as a shared library, I meet following error:
/usr/bin/ld: toolkit.o: relocation R_X86_64_32S against `a local symbol’ can not be used when making a shared object; recompile with -fPIC
toolkit.o: could not read symbols: Bad value
My own compiling command is :
/usr/local/pgi/linux86-64/6.1/bin/pgf90 -shared -fPIC *.o
-L/usr/local/lib64 -lnetcdf
-L/usr/lib64
-L/usr/local/pgi/linux86-64/6.1/libso
-o $output_file
I am using the 6.1 64bit version on a AMD system.
Thanks lots.
No, that’s your link command. You need to compile the source files to .o with -Kpic (or -fpic, PGI seems to accept most common variants).
e.g. you have toolkit.f90:
pgf90 -c -Kpic -otoolkit.o toolkit.f90
Then
pgf90 -shared -fPIC *.o -L/usr/local/lib64 -lnetcdf -L/usr/lib64 -L/usr/local/pgi/linux86-64/6.1/libso
-o $output_file
Thanks the reply. Now the new problem is that:
/usr/bin/ld: /usr/local/lib64/libnetcdf.a(fort-v2compat.o): relocation R_X86_64_32S against `a local symbol’ can not be used when making a shared object; recompile with -fPIC
/usr/local/lib64/libnetcdf.a: could not read symbols: Bad value
I’m not sure whether this kind error comes from my codes or the linking command. If it comes from linking command, what should I do to solve it. My linking command is still the same as above.
Thanks for your time
Hi tingting,
You need to recompile NetCDF with “-fPIC” as well.
