Error when compiling with -ta=nvidia and -Mcuda
I have a code with acc directives wich is currently compiling and working with -ta=nividia option.
I wanted to add in this code some Cuda Fortran kernels. However when I try to compile with option “-ta=nvidia -Mcuda” I then get the following error:
PGF90-F-0701-Error reading temp file - dtype (/users/lapixa/GPU/turb_standalone_1a/src/turb_standalone.f90)
This seems really related with -Mcuda option, as even if I remove all calls to my cuda fortran kernel and the Use Cudafor statment, but compile with -Mcuda I am getting this error.
I have unfortunatelly not been able to reproduce the problem in a smaller test case, and other codes which mix CudaFortran and acc directives are working well. Do you have any idea of what could be causing this issue ?
Regards,
Xavier
PGi version: 11.8
Hi Xavier,
Could you try compiling your code with -v and posting the output here? We will need a little more info to see what is going on.
hi,
Here is the output with -v
/apps/eiger/pgi-11.8/linux86-64/11.8/bin/pgf902 /tmp/pgf90cHHggMGpxGkq.ilm -fn /
users/lapixa/GPU/turb_standalone_1a/src/turb_standalone.f90 -opt 3 -inform infor
m -x 51 0x20 -x 119 0xa10000 -x 122 0x40 -x 123 0x1000 -x 127 4 -x 127 17 -x 19
0x400000 -x 28 0x40000 -x 120 0x10000000 -x 70 0x8000 -x 122 1 -x 125 0x20000 -q
uad -vect 60 -y 34 16 -x 34 0x8 -x 32 6291456 -y 19 8 -y 35 0 -x 42 0x30 -x 39 0
x40 -x 39 0x80 -x 34 0x400000 -x 149 1 -x 150 1 -x 59 4 -x 59 4 -x 6 0x100 -tp i
stanbul -x 120 0x1000 -x 124 0x1400 -y 15 2 -x 57 0x3b0000 -x 58 0x48000000 -x 4
9 0x100 -x 120 0x200 -astype 0 -ieee 1 -inlib /tmp/pgf90IHHgMweiW-Lb.ext -x 14 3
2 -x 124 1 -x 42 0x400000 -x 163 0x10001 -x 176 8 -accel nvidia -x 163 0x40 -x 1
76 0x140000 -x 177 0x0202007f -x 176 8448 -x 137 1 -x 176 0x140000 -x 177 0x0202
007f -x 176 8448 -x 176 8 -quad -x 119 0x10000000 -x 129 0x40000000 -x 129 2 -x
42 0x14200000 -y 39 1 -x 80 0x800000 -x 0 0x1000000 -x 2 0x100000 -x 0 0x2000000
-x 161 16385 -x 162 16385 -cmdline ‘+pgf90 /users/lapixa/GPU/turb_standalone_1a
/src/turb_standalone.f90 -c -I. -I/users/lapixa/GPU/turb_standalone_1a/src -I/ap
ps/eiger/mvapich2/1.5.1p1/mvapich2-gnu/include -D__MPICH2 -Kieee -Mbyteswapio -M
free -Mpreprocess -Minform=inform -D__COSMO__ -ta=nvidia,cc20,nofma -v -Mcuda -M
cache_align -Mflushz -Mlre -Mprefetch -Mpreprocess -Mscalarsse -Mvect=noassoc -M
vect=sse -O3 -Minline -Minfo=inline,accel -o turb_standalone.o’ -asm /tmp/pgf90Y
HHgw6r1CeEf.s
turb_standalone:
702, Generating local(vari(:,:,:))
Generating local(a(:,:,:))
Generating local(tket_hshr_b(:,:))
(here is a long list of generating local, update)
Generating !$acc update host(tkvm_b(:,:))
Generating !$acc update host(tke_b(:,:,:))
779, Generating !$acc update host(gz0_b(:))
0 inform, 0 warnings, 0 severes, 0 fatal for turb_standalone
PGF90/x86-64 Linux 11.8-0: compilation aborted
pgf90-Fatal-f902 completed with exit code 1
Unlinking /tmp/pgf90YHHgwlNbvTE6.ilm
Unlinking /tmp/pgf90cHHggMGpxGkq.ilm
Unlinking /tmp/pgf90sHHg2wLubxBR.cmod
Unlinking /tmp/pgf90IHHgMnqkw7B4.cmdx
Unlinking /tmp/pgf90YHHgw6r1CeEf.s
Unlinking directory /tmp/pgf90IHHgMweiW-Lb.ext
gmake[1]: *** [turb_standalone.o] Error 2
gmake[1]: Leaving directory `/users/lapixa/GPU/turb_standalone_1a/obj’
gmake: *** [paropt] Error 2
Xavier
Hi Xavier,
Can you please send an example code that reproduces the error to PGI Customer Service (trs@pgroup.com)? We have not seen this error before so will need the source to determine what the problem is.
Thanks,
Mat
Hi Mat,
I was away for some days. I have just sent an example to trs@pgroup.com.
Xavier
