- Our Lidar is working fine and is connected, and we get a the visual in Sight. Our Segway RMP 210 is throwing errors however.
jetson@jetson-desktop:~/deploy/shatterhand/gmapping-pkg$ ./apps/carter/gmapping/gmapping
2019-11-06 15:15:17.537 INFO engine/alice/tools/websight.cpp@166: Loading websight...
2019-11-06 15:15:17.537 WARNING engine/alice/backend/application_json_loader.cpp@98: This application does not have an explicit scheduler configuration. One will be autogenerated to the best of the system's abilities if possible.
2019-11-06 15:15:17.539 INFO engine/alice/backend/application_json_loader.cpp@237: Modules requested by subgraph 'imu_odometry': imu, (navigation),
2019-11-06 15:15:17.540 INFO engine/alice/backend/application_json_loader.cpp@237: Modules requested by subgraph 'local_map': (navigation),
2019-11-06 15:15:17.540 WARNING engine/alice/backend/application_json_loader.cpp@241: Loaded a subgraph with no modules section. Did you forget to add one?
2019-11-06 15:15:17.541 INFO engine/alice/backend/application_json_loader.cpp@237: Modules requested by subgraph 'carter_hardware': (imu), segway, velodyne_lidar,
2019-11-06 15:15:17.542 INFO engine/alice/backend/application_json_loader.cpp@237: Modules requested by subgraph 'scan_flattener': perception,
2019-11-06 15:15:17.542 INFO engine/alice/backend/application_json_loader.cpp@237: Modules requested by subgraph 'commander': (navigation), sensors:joystick,
2019-11-06 15:15:17.542 WARNING engine/alice/backend/backend.cpp@168: This application does not have an execution group configuration. One will be autogenerated to the best of the systems abilities if possible.
2019-11-06 15:15:17.543 WARNING engine/gems/scheduler/scheduler.cpp@337: No default execution groups specified. Attempting to create scheduler configuration for 4 remaining cores. This may be non optimal for the system and application.
2019-11-06 15:15:17.543 INFO engine/gems/scheduler/scheduler.cpp@290: Scheduler execution groups are:
2019-11-06 15:15:17.543 INFO engine/gems/scheduler/scheduler.cpp@299: __BlockerGroup__: Cores = [3], Workers = No
2019-11-06 15:15:17.543 INFO engine/gems/scheduler/scheduler.cpp@299: __WorkerGroup__: Cores = [0, 1, 2], Workers = Yes
2019-11-06 15:15:17.570 INFO engine/alice/backend/modules.cpp@283: Loaded module 'packages/imu/libimu_module.so': Now has 43 components total
2019-11-06 15:15:17.606 INFO engine/alice/backend/modules.cpp@283: Loaded module 'packages/navigation/libnavigation_module.so': Now has 81 components total
2019-11-06 15:15:17.730 INFO engine/alice/backend/modules.cpp@283: Loaded module 'packages/perception/libperception_module.so': Now has 91 components total
2019-11-06 15:15:17.772 INFO engine/alice/backend/modules.cpp@283: Loaded module 'packages/segway/libsegway_module.so': Now has 92 components total
2019-11-06 15:15:17.804 INFO engine/alice/backend/modules.cpp@283: Loaded module 'packages/sensors/libjoystick_module.so': Now has 93 components total
2019-11-06 15:15:17.844 INFO engine/alice/backend/modules.cpp@283: Loaded module 'packages/sight/libsight_module.so': Now has 95 components total
2019-11-06 15:15:17.877 INFO engine/alice/backend/modules.cpp@283: Loaded module 'packages/velodyne_lidar/libvelodyne_lidar_module.so': Now has 96 components total
2019-11-06 15:15:17.878 INFO engine/alice/application.cpp@265: Loaded 96 components: isaac::Joystick, isaac::SegwayRmpDriver, isaac::alice::Behavior, isaac::alice::ChannelMonitor, isaac::alice::Config, isaac::alice::ConfigBridge, isaac::alice::Failsafe, isaac::alice::FailsafeHeartbeat, isaac::alice::InteractiveMarkersBridge, isaac::alice::MessageLedger, isaac::alice::NodeStatistics, isaac::alice::Pose, isaac::alice::PoseInitializer, isaac::alice::PoseMessageInjector, isaac::alice::PoseTreeJsonBridge, isaac::alice::PyCodelet, isaac::alice::Recorder, isaac::alice::RecorderBridge, isaac::alice::Replay, isaac::alice::ReplayBridge, isaac::alice::Scheduling, isaac::alice::Sight, isaac::alice::SightChannelStatus, isaac::alice::Subgraph, isaac::alice::Subprocess, isaac::alice::TcpPublisher, isaac::alice::TcpSubscriber, isaac::alice::Throttle, isaac::alice::TimeOffset, isaac::alice::TimeSynchronizer, isaac::alice::UdpPublisher, isaac::alice::UdpSubscriber, isaac::alice::behaviors::Behavior, isaac::alice::behaviors::MemorySelectorBehavior, isaac::alice::behaviors::MemorySequenceBehavior, isaac::alice::behaviors::NodeGroup, isaac::alice::behaviors::ParallelBehavior, isaac::alice::behaviors::SwitchBehavior, isaac::alice::behaviors::TimerBehavior, isaac::imu::IioBmi160, isaac::imu::ImuCalibration2D, isaac::imu::ImuCorrector, isaac::imu::ImuSim, isaac::map::Map, isaac::map::OccupancyGridMapLayer, isaac::map::PolygonMapLayer, isaac::map::WaypointMapLayer, isaac::navigation::BinaryToDistanceMap, isaac::navigation::CollisionMonitor, isaac::navigation::DifferentialBaseOdometry, isaac::navigation::DifferentialBaseWheelImuOdometry, isaac::navigation::DistanceMap, isaac::navigation::FollowPath, isaac::navigation::GoTo, isaac::navigation::GoToBehavior, isaac::navigation::GradientDescentLocalization, isaac::navigation::GridSearchLocalizer, isaac::navigation::GroupSelectorBehavior, isaac::navigation::HolonomicBaseWheelImuOdometry, isaac::navigation::LocalMap, isaac::navigation::LocalizationEvaluation, isaac::navigation::LocalizeBehavior, isaac::navigation::MapWaypointAsGoal, isaac::navigation::MapWaypointAsGoalSimulator, isaac::navigation::MoveAndScan, isaac::navigation::NavigationMap, isaac::navigation::NavigationMonitor, isaac::navigation::ObstacleWorld, isaac::navigation::OccupancyMapCleanup, isaac::navigation::OccupancyToBinaryMap, isaac::navigation::ParticleFilterLocalization, isaac::navigation::ParticleSwarmLocalization, isaac::navigation::Patrol, isaac::navigation::PoseAsGoal, isaac::navigation::RandomWalk, isaac::navigation::RangeScanModelClassic, isaac::navigation::RangeScanModelFlatloc, isaac::navigation::RobotRemoteControl, isaac::navigation::RobotViewer, isaac::navigation::SelectorBehavior, isaac::navigation::TravellingSalesman, isaac::navigation::VirtualGamepadBridge, isaac::perception::CropAndDownsampleCpu, isaac::perception::CropAndDownsampleCuda, isaac::perception::EstimateGroundPlane, isaac::perception::EstimateObstacleDistances, isaac::perception::FiducialAsGoal, isaac::perception::ImageUndistortion, isaac::perception::PointCloudAccumulator, isaac::perception::RangeScanFlattening, isaac::perception::RangeToPointCloud, isaac::perception::ScanAccumulator, isaac::sight::AliceSight, isaac::sight::WebsightServer, isaac::velodyne_lidar::VelodyneLidar, navigation::GMappingNode,
2019-11-06 15:15:17.878 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node 'websight'
2019-11-06 15:15:17.880 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='websight', component='WebsightServer', key='tick_period'
2019-11-06 15:15:17.881 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='websight', component='isaac.sight.AliceSight', key='tick_period'
2019-11-06 15:15:17.881 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node '_config_bridge'
2019-11-06 15:15:17.881 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='_config_bridge', component='isaac.alice.ConfigBridge', key='tick_period'
2019-11-06 15:15:17.881 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node '_statistics'
2019-11-06 15:15:17.881 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node '_pose_tree_bridge'
2019-11-06 15:15:17.881 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node '_interactive_markers_bridge'
2019-11-06 15:15:17.881 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node 'gmapping'
2019-11-06 15:15:17.882 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='gmapping', component='navigation.GMappingNode', key='tick_period'
2019-11-06 15:15:17.882 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node 'imu_odometry.subgraph'
2019-11-06 15:15:17.882 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node 'imu_odometry.odometry'
2019-11-06 15:15:17.882 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node 'imu_odometry.imu_corrector'
2019-11-06 15:15:17.882 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='imu_odometry.imu_corrector', component='ImuCorrector', key='tick_period'
2019-11-06 15:15:17.882 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='imu_odometry.imu_corrector', component='ImuCorrector', key='calibration_file'
2019-11-06 15:15:17.882 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node 'local_map.subgraph'
2019-11-06 15:15:17.882 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node 'local_map.local_map'
2019-11-06 15:15:17.882 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='local_map.local_map', component='cleanup', key='tick_period'
2019-11-06 15:15:17.882 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='local_map.local_map', component='cleanup', key='additional_clear_region'
2019-11-06 15:15:17.882 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='local_map.local_map', component='isaac.navigation.BinaryToDistanceMap', key='tick_period'
2019-11-06 15:15:17.882 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='local_map.local_map', component='isaac.navigation.LocalMap', key='tick_period'
2019-11-06 15:15:17.883 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='local_map.local_map', component='isaac.navigation.OccupancyToBinaryMap', key='tick_period'
2019-11-06 15:15:17.883 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node '2d_carter.subgraph'
2019-11-06 15:15:17.883 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node '2d_carter.carter_hardware.subgraph'
2019-11-06 15:15:17.883 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node '2d_carter.carter_hardware.segway_rmp'
2019-11-06 15:15:17.883 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node '2d_carter.carter_hardware.vlp16'
2019-11-06 15:15:17.883 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='2d_carter.carter_hardware.vlp16', component='VelodyneLidar', key='tick_period'
2019-11-06 15:15:17.883 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='2d_carter.carter_hardware.vlp16', component='lidar_initializer', key='tick_period'
2019-11-06 15:15:17.884 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node '2d_carter.carter_hardware.imu'
2019-11-06 15:15:17.884 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node '2d_carter.scan_flattener.subgraph'
2019-11-06 15:15:17.884 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node '2d_carter.scan_flattener.scan_accumulator'
2019-11-06 15:15:17.884 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='2d_carter.scan_flattener.scan_accumulator', component='isaac.perception.ScanAccumulator', key='tick_period'
2019-11-06 15:15:17.884 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node '2d_carter.scan_flattener.range_scan_flattening'
2019-11-06 15:15:17.884 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='2d_carter.scan_flattener.range_scan_flattening', component='isaac.perception.RangeScanFlattening', key='tick_period'
2019-11-06 15:15:17.884 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='2d_carter.scan_flattener.range_scan_flattening', component='isaac.perception.RangeScanFlattening', key='target_pitch'
2019-11-06 15:15:17.884 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node 'commander.subgraph'
2019-11-06 15:15:17.884 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node 'commander.joystick'
2019-11-06 15:15:17.885 WARNING engine/alice/hooks/config_hook.cpp@59: Configuration does not contain a value and no default provided: node='commander.joystick', component='isaac.Joystick', key='tick_period'
2019-11-06 15:15:17.885 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node 'commander.virtual_gamepad_bridge'
2019-11-06 15:15:17.885 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node 'commander.robot_remote'
2019-11-06 15:15:17.885 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node 'recorder'
2019-11-06 15:15:17.885 DEBUG engine/alice/backend/node_backend.cpp@49: Creating node 'recorder_bridge'
2019-11-06 15:15:17.886 WARNING engine/alice/application.cpp@173: The function Application::findComponentByName is deprecated. Please use `getNodeComponentOrNull` instead. Note that the new method requires a node name instead of a component name. (argument: 'websight/isaac.sight.AliceSight')
2019-11-06 15:15:17.886 INFO engine/alice/application.cpp@213: Starting application 'gmapping' (instance UUID: '2663cf4c-00d2-11ea-bc4c-b5166e886b71') ...
2019-11-06 15:15:17.886 DEBUG engine/gems/scheduler/execution_groups.cpp@484: Launching 0 pre-start job(s)
2019-11-06 15:15:17.886 DEBUG engine/gems/scheduler/execution_groups.cpp@493: Replaying 0 pre-start event(s)
2019-11-06 15:15:17.886 INFO engine/alice/backend/asio_backend.cpp@33: Starting ASIO service
2019-11-06 15:15:17.896 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node 'websight'
2019-11-06 15:15:17.896 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'websight/WebsightServer' ...
2019-11-06 15:15:17.897 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet 'websight/WebsightServer' DONE
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet 'websight/WebsightServer'
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'websight/isaac.sight.AliceSight' ...
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet 'websight/isaac.sight.AliceSight' DONE
2019-11-06 15:15:17.898 WARNING engine/alice/backend/codelet_backend.cpp@281: Codelet 'websight/isaac.sight.AliceSight' was not added to scheduler because no tick method is specified.
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node '_config_bridge'
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet '_config_bridge/isaac.alice.ConfigBridge' ...
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet '_config_bridge/isaac.alice.ConfigBridge' DONE
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet '_config_bridge/isaac.alice.ConfigBridge'
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node '_statistics'
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet '_statistics/NodeStatistics' ...
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet '_statistics/NodeStatistics' DONE
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet '_statistics/NodeStatistics'
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node '_pose_tree_bridge'
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet '_pose_tree_bridge/PoseTreeJsonBridge' ...
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet '_pose_tree_bridge/PoseTreeJsonBridge' DONE
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet '_pose_tree_bridge/PoseTreeJsonBridge'
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node '_interactive_markers_bridge'
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet '_interactive_markers_bridge/InteractiveMarkersBridge' ...
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet '_interactive_markers_bridge/InteractiveMarkersBridge' DONE
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet '_interactive_markers_bridge/InteractiveMarkersBridge'
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node 'recorder_bridge'
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'recorder_bridge/RecorderBridge' ...
2019-11-06 15:15:17.898 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet 'recorder_bridge/RecorderBridge' DONE
2019-11-06 15:15:17.899 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet 'recorder_bridge/RecorderBridge'
2019-11-06 15:15:17.899 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node 'recorder'
2019-11-06 15:15:17.899 WARNING engine/alice/application.cpp@173: The function Application::findComponentByName is deprecated. Please use `getNodeComponentOrNull` instead. Note that the new method requires a node name instead of a component name. (argument: 'recorder/isaac.alice.Recorder')
2019-11-06 15:15:17.899 INFO engine/gems/cask/cask.cpp@58: Creating new log '/tmp/isaac/2663cf4c-00d2-11ea-bc4c-b5166e886b71/kv' for writing
2019-11-06 15:15:17.899 WARNING engine/alice/components/RecorderBridge.cpp@66: Recording disabled since no channels are connected to Recorder component
2019-11-06 15:15:17.899 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node 'commander.robot_remote'
2019-11-06 15:15:17.899 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'commander.robot_remote/isaac.navigation.RobotRemoteControl' ...
2019-11-06 15:15:17.899 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet 'commander.robot_remote/isaac.navigation.RobotRemoteControl' DONE
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet 'commander.robot_remote/isaac.navigation.RobotRemoteControl'
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node 'commander.virtual_gamepad_bridge'
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'commander.virtual_gamepad_bridge/VirtualGamepadBridge' ...
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet 'commander.virtual_gamepad_bridge/VirtualGamepadBridge' DONE
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet 'commander.virtual_gamepad_bridge/VirtualGamepadBridge'
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node 'commander.joystick'
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'commander.joystick/isaac.Joystick' ...
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet 'commander.joystick/isaac.Joystick' DONE
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet 'commander.joystick/isaac.Joystick'
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node 'commander.subgraph'
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node '2d_carter.scan_flattener.range_scan_flattening'
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet '2d_carter.scan_flattener.range_scan_flattening/isaac.perception.RangeScanFlattening' ...
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet '2d_carter.scan_flattener.range_scan_flattening/isaac.perception.RangeScanFlattening' DONE
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet '2d_carter.scan_flattener.range_scan_flattening/isaac.perception.RangeScanFlattening'
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node '2d_carter.scan_flattener.scan_accumulator'
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet '2d_carter.scan_flattener.scan_accumulator/isaac.perception.ScanAccumulator' ...
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet '2d_carter.scan_flattener.scan_accumulator/isaac.perception.ScanAccumulator' DONE
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet '2d_carter.scan_flattener.scan_accumulator/isaac.perception.ScanAccumulator'
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node '2d_carter.scan_flattener.subgraph'
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node '2d_carter.carter_hardware.imu'
2019-11-06 15:15:17.900 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet '2d_carter.carter_hardware.imu/IioBmi160' ...
2019-11-06 15:15:18.163 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet '2d_carter.carter_hardware.imu/IioBmi160' DONE
2019-11-06 15:15:18.163 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet '2d_carter.carter_hardware.imu/IioBmi160'
2019-11-06 15:15:18.164 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node '2d_carter.carter_hardware.vlp16'
2019-11-06 15:15:18.164 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet '2d_carter.carter_hardware.vlp16/VelodyneLidar' ...
2019-11-06 15:15:18.164 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet '2d_carter.carter_hardware.vlp16/VelodyneLidar' DONE
2019-11-06 15:15:18.164 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet '2d_carter.carter_hardware.vlp16/VelodyneLidar'
2019-11-06 15:15:18.164 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet '2d_carter.carter_hardware.vlp16/lidar_initializer' ...
2019-11-06 15:15:18.164 WARNING engine/alice/components/Codelet.cpp@87: Function deprecated. Set tick_period to the desired tick paramater
2019-11-06 15:15:18.164 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet '2d_carter.carter_hardware.vlp16/lidar_initializer' DONE
2019-11-06 15:15:18.164 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet '2d_carter.carter_hardware.vlp16/lidar_initializer'
2019-11-06 15:15:18.164 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node '2d_carter.carter_hardware.segway_rmp'
2019-11-06 15:15:18.164 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet '2d_carter.carter_hardware.segway_rmp/isaac.SegwayRmpDriver' ...
2019-11-06 15:15:19.185 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 765f3548 765f354a 765f354e 765f3552
2019-11-06 15:15:20.209 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 765f3548 765f354a 765f354e 765f3552
2019-11-06 15:15:21.233 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 765f3548 765f354a 765f354e 765f3552
2019-11-06 15:15:22.257 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 765f3548 765f354a 765f354e 765f3552
2019-11-06 15:15:23.281 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 765f3688 765f368a 765f368e 765f3692
2019-11-06 15:15:24.305 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 765f3688 765f368a 765f368e 765f3692
2019-11-06 15:15:24.305 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet '2d_carter.carter_hardware.segway_rmp/isaac.SegwayRmpDriver' DONE
2019-11-06 15:15:24.305 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet '2d_carter.carter_hardware.segway_rmp/isaac.SegwayRmpDriver'
2019-11-06 15:15:24.305 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node '2d_carter.carter_hardware.subgraph'
2019-11-06 15:15:24.305 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node '2d_carter.subgraph'
2019-11-06 15:15:24.305 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node 'local_map.local_map'
2019-11-06 15:15:24.305 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'local_map.local_map/cleanup' ...
2019-11-06 15:15:24.306 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet 'local_map.local_map/cleanup' DONE
2019-11-06 15:15:24.306 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet 'local_map.local_map/cleanup'
2019-11-06 15:15:24.306 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'local_map.local_map/isaac.navigation.BinaryToDistanceMap' ...
2019-11-06 15:15:24.306 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet 'local_map.local_map/isaac.navigation.BinaryToDistanceMap' DONE
2019-11-06 15:15:24.306 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet 'local_map.local_map/isaac.navigation.BinaryToDistanceMap'
2019-11-06 15:15:24.306 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'local_map.local_map/isaac.navigation.LocalMap' ...
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet 'local_map.local_map/isaac.navigation.LocalMap' DONE
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet 'local_map.local_map/isaac.navigation.LocalMap'
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'local_map.local_map/isaac.navigation.OccupancyToBinaryMap' ...
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet 'local_map.local_map/isaac.navigation.OccupancyToBinaryMap' DONE
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet 'local_map.local_map/isaac.navigation.OccupancyToBinaryMap'
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node 'local_map.subgraph'
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node 'imu_odometry.imu_corrector'
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'imu_odometry.imu_corrector/ImuCorrector' ...
2019-11-06 15:15:24.307 INFO packages/imu/ImuCorrector.cpp@43: No calibration file is supplied. Corrector will calibrate IMU.
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet 'imu_odometry.imu_corrector/ImuCorrector' DONE
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet 'imu_odometry.imu_corrector/ImuCorrector'
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node 'imu_odometry.odometry'
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'imu_odometry.odometry/DifferentialBaseWheelImuOdometry' ...
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet 'imu_odometry.odometry/DifferentialBaseWheelImuOdometry' DONE
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet 'imu_odometry.odometry/DifferentialBaseWheelImuOdometry'
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node 'imu_odometry.subgraph'
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/node_backend.cpp@317: Starting node 'gmapping'
2019-11-06 15:15:24.307 DEBUG engine/alice/backend/codelet_backend.cpp@61: Starting codelet 'gmapping/navigation.GMappingNode' ...
-maxUrange 10 -maxUrange 34 -sigma 0.05 -kernelSize 1 -lstep 0.01 -lobsGain 3 -astep 0.01
-srr 0.0872665 -srt 0 -str 0 -stt 0.05
-linearUpdate 0.2 -angularUpdate 0.08 -resampleThreshold 0.5
-xmin -100 -xmax 100 -ymin -100 -ymax 100 -delta 0.05 -particles 150
2019-11-06 15:15:24.315 INFO packages/imu/ImuCorrector.cpp@116: Collecting IMU data to calibrate...
2019-11-06 15:15:24.442 DEBUG engine/alice/backend/codelet_backend.cpp@73: Starting codelet 'gmapping/navigation.GMappingNode' DONE
2019-11-06 15:15:24.442 DEBUG engine/alice/backend/codelet_backend.cpp@291: Starting job for codelet 'gmapping/navigation.GMappingNode'
2019-11-06 15:15:25.329 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:25.329 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
2019-11-06 15:15:26.357 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:26.357 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
2019-11-06 15:15:27.307 WARNING packages/navigation/DifferentialBaseWheelImuOdometry.cpp@155: Haven't received any IMU data. Please check the edges. If no IMU is available, please set 'use_imu' to false.
2019-11-06 15:15:27.377 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:27.377 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
2019-11-06 15:15:27.404 DEBUG packages/imu/gems/imu_calibration.cpp@98: Calibrated IMU data after 310 samples.
2019-11-06 15:15:27.404 DEBUG packages/imu/gems/imu_calibration.cpp@99: Maximum variation in acceleration sample window is 0.084655.
2019-11-06 15:15:27.404 DEBUG packages/imu/ImuCorrector.cpp@138: Finished IMU calibration.
update frame 0
update ld=0 ad=0
m_count 0
Registering First Scan
2019-11-06 15:15:27.591 INFO packages/navigation/GMappingNode.cpp@238: Pose 0.003802 0.000000 0.040047 - 0.000000 0.000000 0.000000
2019-11-06 15:15:28.401 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:28.401 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
2019-11-06 15:15:29.425 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:29.425 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
update frame 1
update ld=0.00164813 ad=0.255746
m_count 1
2019-11-06 15:15:30.449 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:30.449 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
2019-11-06 15:15:31.473 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:31.473 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
2019-11-06 15:15:32.497 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:32.497 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
2019-11-06 15:15:33.521 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:33.521 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
2019-11-06 15:15:34.545 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:34.545 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
2019-11-06 15:15:35.569 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:35.569 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
2019-11-06 15:15:36.593 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:36.593 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
2019-11-06 15:15:37.621 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:37.621 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
2019-11-06 15:15:38.641 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:38.641 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
2019-11-06 15:15:39.665 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:39.665 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
2019-11-06 15:15:40.689 ERROR packages/segway/gems/segway.cpp@110: Command probably invalid (error -1) 57ffe498 57ffe49a 57ffe49e 57ffe4a2
2019-11-06 15:15:40.689 ERROR packages/segway/SegwayRmpDriver.cpp@89: Failed to send command
- The application does not crash, it keeps going and throwing the errors.
- The segway error messages print about every second.
- We are using the velodyne vlp16 lidar. We had to manually set the IP in the network settings, and now it is working.
- The Jetson is connected to our work network. But the lidar and segway are connected to the jetson using ethernet.
However, instead of using the ethernet cable, when the USB is connected it seems to be detected with ‘lsusb’. Is it possible to use the USB? it seems there are no explicit parameters in isaac to do so.
