Error when flashing OS to TX1
Hello! I am trying to update my TX1 to have Ubuntu 16.04 64amd with JetPack, and every time I try to connect the two through my router I receive the following error code:
Return Code: 127
/bin/bash: xterm: command not found
I have the Jetson in recovery mode, both are connected to the router, and I have the USB cord plugged into the Jetson from the host PC. Do you have any suggestions?
  • LinuxCorps
It sounds like JetPack needs “xterm”. Try “sudo apt-get install xterm”.
