I try to run:
jetson-containers run --workdir=/opt/text-generation-webui $(autotag text-generation-webui) python3 download-model.py --output=/data/models/text-generation-webui TheBloke/llava-v1.5-13B-GPTQ
error message: Error response from daemon: pull access denied for python3, repository does not exist or may require ‘docker login’: denied: requested access to the resource is denied
I can successfully login nvcr.io
pkwok@X1:~$ sudo docker login nvcr.io
Username: $oauthtoken
Password:
WARNING! Your password will be stored unencrypted in /root/.docker/config.json.
Configure a credential helper to remove this warning. See
docker login | Docker Docs
Login Succeeded
