Error when installing Isaacsim using pip
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: RTX 5090
  • Driver Version: 575.57.08
Topic Description
Detailed Description
I cant install isaacsim using pip (i’m following tutorial from Installation using Isaac Sim pip — Isaac Lab Documentation), how can i solve it?
Steps to Reproduce
(Add more steps as needed)
Error Messages
(isaaclab_mnt) pbazan@lvci-07:~$ pip install ‘isaacsim[all,extscache]==4.5.0’ --extra-index-url https://pypi.nvidia.com
Looking in indexes: Simple index, https://pypi.nvidia.com
Collecting isaacsim==4.5.0 (from isaacsim[all,extscache]==4.5.0)
Using cached isaacsim-4.5.0.0.tar.gz (1.1 kB)
Installing build dependencies … done
Getting requirements to build wheel … done
Preparing metadata (pyproject.toml) … error
error: subprocess-exited-with-error
× Preparing metadata (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [72 lines of output]
File “/tmp/pip-build-env-a0gzcjd7/overlay/lib/python3.10/site-packages/wheel_stub/wheel.py”, line 249, in download_wheel
return download_manual(wheel_directory, distribution, version, config)
File “/tmp/pip-build-env-a0gzcjd7/overlay/lib/python3.10/site-packages/wheel_stub/wheel.py”, line 176, in download_manual
raise RuntimeError(f"Failed to open project URL {project_url}") from e
File “/tmp/pip-build-env-a0gzcjd7/overlay/lib/python3.10/site-packages/wheel_stub/wheel.py”, line 174, in download_manual
index_response = urlopen_with_retry(project_url)
File “/tmp/pip-build-env-a0gzcjd7/overlay/lib/python3.10/site-packages/wheel_stub/wheel.py”, line 92, in urlopen_with_retry
return urlopen(url, **kwargs)
File “/home/pbazan/anaconda3/envs/isaaclab_mnt/lib/python3.10/urllib/request.py”, line 216, in urlopen
return opener.open(url, data, timeout)
File “/home/pbazan/anaconda3/envs/isaaclab_mnt/lib/python3.10/urllib/request.py”, line 525, in open
response = meth(req, response)
File “/home/pbazan/anaconda3/envs/isaaclab_mnt/lib/python3.10/urllib/request.py”, line 634, in http_response
response = self.parent.error(
File “/home/pbazan/anaconda3/envs/isaaclab_mnt/lib/python3.10/urllib/request.py”, line 563, in error
return self._call_chain(*args)
File “/home/pbazan/anaconda3/envs/isaaclab_mnt/lib/python3.10/urllib/request.py”, line 496, in _call_chain
result = func(*args)
File “/home/pbazan/anaconda3/envs/isaaclab_mnt/lib/python3.10/urllib/request.py”, line 643, in http_error_default
raise HTTPError(req.full_url, code, msg, hdrs, fp)
urllib.error.HTTPError: HTTP Error 404: Not Found
  The above exception was the direct cause of the following exception:
    File "/tmp/pip-build-env-a0gzcjd7/overlay/lib/python3.10/site-packages/wheel_stub/wheel.py", line 249, in download_wheel
    File "/tmp/pip-build-env-a0gzcjd7/overlay/lib/python3.10/site-packages/wheel_stub/wheel.py", line 176, in download_manual
  RuntimeError: Failed to open project URL https://pypi.nvidia.com/isaacsim/
  During handling of the above exception, another exception occurred:
    File "/home/pbazan/anaconda3/envs/isaaclab_mnt/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 389, in <module>
      main()
    File "/home/pbazan/anaconda3/envs/isaaclab_mnt/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 373, in main
      json_out["return_val"] = hook(**hook_input["kwargs"])
    File "/home/pbazan/anaconda3/envs/isaaclab_mnt/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 178, in prepare_metadata_for_build_wheel
      whl_basename = backend.build_wheel(metadata_directory, config_settings)
    File "/tmp/pip-build-env-a0gzcjd7/overlay/lib/python3.10/site-packages/wheel_stub/buildapi.py", line 29, in build_wheel
      return download_wheel(pathlib.Path(wheel_directory), config_settings)
    File "/tmp/pip-build-env-a0gzcjd7/overlay/lib/python3.10/site-packages/wheel_stub/wheel.py", line 251, in download_wheel
      report_install_failure(distribution, version, config, exception_context)
    File "/tmp/pip-build-env-a0gzcjd7/overlay/lib/python3.10/site-packages/wheel_stub/error.py", line 67, in report_install_failure
      raise InstallFailedError(
  wheel_stub.error.InstallFailedError:
  The installation of isaacsim for version 4.5.0.0 failed.
  This is a special placeholder package which downloads a real wheel package
  from https://pypi.nvidia.com/. If https://pypi.nvidia.com/ is not reachable, we
  cannot download the real wheel file to install.
  You might try installing this package via
  $ pip install --extra-index-url https://pypi.nvidia.com/ isaacsim
  Here is some debug information about your platform to include in any bug
  report:
  Python Version: CPython 3.10.18
  Operating System: Linux 6.11.0-28-generic
  CPU Architecture: x86_64
  CUDA Version: 12.9
  [end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
I’m having the same problem as you. Although the officials have found this problem, they haven’t solved it yet.
As mentioned in the other post, it is temporary error we are working on, but we not have ISAAC SIM 5.0 ! Just install that GitHub - isaac-sim/IsaacSim: NVIDIA Isaac Sim™ is an open-source application on NVIDIA Omniverse for developing, simulating, and testing AI-driven robots in realistic virtual environments. Don’t install the old version
thanks for the reply, but im still confuse how can i use isaaclab with this new version of isaacsim, i just need to follow the current tutorial of isaaclab? Installation using Isaac Sim pip — Isaac Lab Documentation
