I want to setup JETSON XAVIER.But bellow error was occur.
Is there any solution?
HOST PC:ubuntu18.04
JetPack4.3
TERMINAL
15:26:53 ERROR : CUDA on Host : E: Failed to fetch http://jp.archive.ubuntu.com/ubuntu/dists/bionic-updates/main/binary-arm64/Packages 404 Not Found [IP: 160.26.2.187 80]
15:26:54 ERROR : CUDA on Host : E: Unable to correct problems, you have held broken packages.
15:26:54 ERROR : CUDA on Host : apt install failed
15:26:54 ERROR : CUDA on Host : command terminated with error
15:26:54 ERROR : CUDA on Host : install ‘CUDA on Host’ failure, command < cd ‘/home/mitsuishi/nvidia/nvidia_sdk/JetPack_4.3_Linux’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_CUDA_HOST_COMP’ -v=‘10.0’ -l=‘/home/mitsuishi/nvidia/nvidia_sdk/JetPack_4.3_Linux’ -L=‘/home/mitsuishi/.nvsdkm/logs/JetPack_4.3_Linux’ -p=‘12043’ -t=‘host’ -e=‘/home/mitsuishi/Downloads/nvidia/sdkm_downloads/cuda-repo-ubuntu1804-10-0-local-10.0.326-410.108_1.0-1_amd64.deb’ > terminated with error
15:26:54 ERROR : Unavailable components detected, please check log
15:26:54 ERROR : OpenCV on Host : OpenCV on Host Skipped. Due to its dependencies fail to install: CUDA on Host,
15:26:54 ERROR : VisionWorks on Host : VisionWorks on Host Skipped. Due to its dependencies fail to install: CUDA on Host,
15:26:54 ERROR : CUDA Cross Compile Package on Host : CUDA Cross Compile Package on Host Skipped. Due to its dependencies fail to install: CUDA on Host,
15:26:55 ERROR : Could not detect Nvidia Jetson device connected to USB. Verify that: 1. is connected to this host machine with a USB cable. 2. Jetson’s Ubuntu OS is up and running. 3. Ubuntu ‘System configuration wizard’ is completed on the device. This can be validated by running the ‘lsusb’ command on your host, and look for “0955:7019” (NVIDIA Corp). Or use the ‘Manual Setup’ instead.
15:27:17 ERROR : Could not detect Nvidia Jetson device connected to USB. Verify that: 1. is connected to this host machine with a USB cable. 2. Jetson’s Ubuntu OS is up and running. 3. Ubuntu ‘System configuration wizard’ is completed on the device. This can be validated by running the ‘lsusb’ command on your host, and look for “0955:7019” (NVIDIA Corp). Or use the ‘Manual Setup’ instead.
