Error when launched example packages
I’m new to Isaac ROS, and I have been facing the same problem for the last couple of days. I don’t have any hardware sensors or jetson, so I’ve been trying out tutorials that support x86_64 & Isaac Sim.
I have pulled the image from the Nvidia docker – followed the exact steps from the Dev. configuration.
Following is the error I get whenever I launch the example package.
(To be specific, when I tried Isaac Perceptor in Isaac Sim, [Object Detection using Isaac ROS](https://nvidia-isaac-ros.github.io/repositories_aSnetnet1!
nd_packages/isaac_ros_object_detection/isaac_ros_detectnet/index.html), Isaac Manipulator Reference Workflows with Isaac Sim)
I am using Ubuntu 22.04 and Issac Sim 4.5 on L40S.
I’ve tried setting up Isaac ROS & launching packages on my colleague’s laptop and it worked fine. One major difference we have is that he uses server via mobaXterm and I am using VMware Horizon client.
I have rebooted my VM just to make sure there’s no collision btw packages, but the error stays the same.
I don’t think having a docker container on a VM makes a huge difference; but I’m new to docker so please lmk if that might be an issue.
Below are my cuda/driver info that might be useful. The first one is from the local host and the second one is from the docker container.
I am new to nvidia stack as well, so any insights would be greatly appreciated!
Hi @spearmintorbit
Thank you for your post, and welcome to the Isaac ROS forum.
For running Isaac ROS 3.2 on x86 platform, please follow the computer setup to use native Ubuntu 22.04 or WSL.
Best,
Ahung
