Hi!
It’s great to finally have access to ISAAC Sim!
I followed the install successfully, however in the “Quick start” “Carter” section, when I launch the carter_sim application, I have the following error:
~/workspace/isaac$ bazel run apps/carter_sim:carter_sim -- --config="apps/assets/maps/carter_warehouse_p.config.json" --graph="apps/assets/maps/carter_warehouse_p.graph.json"
Extracting Bazel installation...
Starting local Bazel server and connecting to it...
INFO: Repository rule 'com_github_googlecartographer_cartographer' returned: {"remote": "https://github.com/googlecartographer/cartographer.git", "commit": "b6b41e9b173ea2e49e606f1e0d54d6d57ed421e3", "shallow_since": "2018-08-10", "init_submodules": False, "verbose": False, "strip_prefix": "", "patches": [], "patch_tool": "patch", "patch_args": ["-p0"], "patch_cmds": [], "name": "com_github_googlecartographer_cartographer"}
INFO: Repository rule 'com_github_nelhage_rules_boost' returned: {"remote": "https://github.com/nelhage/rules_boost.git", "commit": "bd05f7b51d25396f30639d31fa78b55a3c1db182", "shallow_since": "2018-08-09", "init_submodules": False, "verbose": False, "strip_prefix": "", "patches": [], "patch_tool": "patch", "patch_args": ["-p0"], "patch_cmds": [], "name": "com_github_nelhage_rules_boost"}
ERROR: /home/cyril/workspace/isaac/packages/map/BUILD:5:12: Configurable attribute "data" doesn't match this configuration (would a default condition help?).
Conditions checked:
//engine/build:platform_x86_64
//engine/build:platform_jetpack42
ERROR: Analysis of target '//apps/carter_sim:carter_sim' failed; build aborted:
Conditions checked:
INFO: Elapsed time: 10.260s
INFO: 0 processes.
FAILED: Build did NOT complete successfully (16 packages loaded, 90 targets co\
nfigured)
currently loading: @bazel_tools//src/tools/launcher
Any idea how to solve that ?
