I would like to use the latest image of Transfer Learning Toolkit for Video Streaming Analytics | NVIDIA NGC.
Unfortunately the version v2.0_py3:
Pulling docker image nvcr.io/nvidia/tlt-streamanalytics:v2.0_py3 ...
Using docker image sha256:eefcf17a78302ecaad83f405f0ff8f1d9709c5c379d1f82f76502687dd4aa9f0
Raise the following error:
`Archive: /opt/ngccli/ngccli_reg_linux.zip`
` inflating: /opt/ngccli/ngc `
` extracting: /opt/ngccli/ngc.md5 `
`/usr/local/bin/install_ngc_cli.sh: eval: line 27: syntax error near unexpected token `then'`
Looks like a typo in shell script! Anyway rolling back to :
`Pulling docker image nvcr.io/nvidia/tlt-streamanalytics:v1.0.1_py2 ...` `Using docker image sha256:5e2cce534d6ea72c2b22ba26fd2a7d78c2ce0beec293af55d3963eba09f9a283`
Work as expected. Would you mind fix the shell file and update the image in order to make it work. Thank you.
