Error when reflashing Jetson Nano
Hi all,
I’m trying to reflash my reComputer J1020 with sdk manager following carefully this guide reComputer J1020 | A206 | Seeed Studio Wiki but it keeps failing when installing. Here is a screenshot of the terminal:
Do you have an idea of what I’m doing wrong? I am following the guide very carefully.
There is a “EXPORT LOGS” button on SDKM. Please use it to dump full log.
SDKM_logs_JetPack_4.6.1_Linux_for_Jetson_Nano_modules_2023-05-02_11-11-19.zip (97.2 KB)
This is what I get.
Where do you run the sdkmanager tool? I mean the host environment.
I’m not sure I got your question but I’m using a host PC with Ubuntu 18.04
I mean is that a VM or something similar?
No I have physically another pc connected to the jetson with USB-C
Is “apt-get update” command on your host working fine? If any error there, then sdkm will have problem too.
Actually it’s not
Thanks for the patience I’m not a linux pro :)
Thanks a lot, that was the issue!
