Error when run deepstream_python_apps/apps/deepstream-imagedata-multistream with custom rtsp
• Hardware Platform (Jetson / GPU) RTX 3060
• DeepStream Version 6.1
• TensorRT Version 8.4.3-1+cuda11.6
• NVIDIA GPU Driver Version (valid for GPU only) 510.85.02
• Issue Type( questions, new requirements, bugs) bugs
When I run command python3 deepstream_imagedata-multistream.py rtsp://username:password@some-host-name.ddns.net:port/cam/realmonitor?channel=1&subtype=0 frame it produces below issues
I followed the instruction here, just replace the rtsp by my rtsp and the issues appeared, I don’t know why
Could anyone help? Thanks in advanced
Any update on this?
It failed at mkdir, it looking for directory “rtsp://***”, please check your script.
I used the same script as here. I didn’t change anything in the script, so why did it fail?
Please share the command you used.
I used this command
Please check your envrionments and do triage. i can run success using this app.
It’s so strange that when I run command python3 deepstream_imagedata-multistream.py rtsp://127.0.0.1/video1 rtsp://127.0.0.1/video2 frames as instructed here, it run okay. But then I run this command python3 deepstream_imagedata-multistream.py rtsp://username:password@some-host-name.ddns.net:port/cam/realmonitor?channel=1&subtype=0 frame the bug still persists
How about quoted rtsp://username:password@some-host-name.ddns.net:port/cam/realmonitor?channel=1&subtype=0
