Error when running cuda-memcheck on command line.
Alright so when I don’t use cuda-memcheck this program calculates essentially what I expect for small values of nPhotons (~1000), but if nPhotons becomes too large (~100000) it is likely to not complete. I thought this could be a memory error so I ran cuda-memcheck from the command line and it gives me a lot of errors.
========= Program hit cudaErrorUnknown (error 30) due to "unknown error" on CUDA API call to cudaMemcpy.
=========     Saved host backtrace up to driver entry point at error
=========     Host Frame:C:\WINDOWS\system32\nvcuda.dll (cuTexRefSetAddress + 0x2cae4e) [0x2d849b]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0x173f]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xda8d]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0x1db45]
=========     Host Frame:C:\WINDOWS\System32\KERNEL32.DLL (BaseThreadInitThunk + 0x14) [0x11fe4]
=========     Host Frame:C:\WINDOWS\SYSTEM32\ntdll.dll (RtlUserThreadStart + 0x21) [0x6ef91]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdaae]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdacf]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdaf0]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdb11]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdb32]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdb53]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdb74]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdb95]
========= Program hit cudaErrorUnknown (error 30) due to "unknown error" on CUDA API call to cudaFree.
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0x15ed]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdcb1]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdcbe]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdccb]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdcd8]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdce5]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdcf2]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdcff]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdd0c]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xdd19]
========= Program hit CUDA_ERROR_UNKNOWN (error 999) due to "unknown error" on CUDA API call to cuModuleUnload.
=========     Host Frame:C:\WINDOWS\system32\nvcuda.dll (cuTexRefSetAddress + 0x1bba01) [0x1c904e]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0x8476]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0x9168]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0xbd06]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0x5d6f]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0x61e6]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0x30b93]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0x30e39]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0x28ad8]
=========     Host Frame:C:\Users\zacha\Documents\GitHub\MCRT_Src\Test_cuda\Test_cuda\a.exe [0x1db57]
========= ERROR SUMMARY: 19 errors
So I can’t figure out what is wrong with this or why the program fails at higher nPhotons. I’m guessing this is a simple error, but I’m at a loss.
#include <iostream>
#include <fstream>
#include <cstdlib>
#include <ctime>
#include <math.h>
#include <cuda.h>
#include <curand.h>
#include <curand_kernel.h>
#include <stdlib.h>
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#define PI 3.14159265
#define MAX 4294967296
using namespace std;
//Generate random numbers
__device__ float rando() {
	curandState_t state;
	curand_init(clock64(), threadIdx.x, 0, &state);
	return (float)curand(&state) / MAX;
//Initialization of photons
__device__ void new_photon(float *photon){
	float cosTh = rando();
	photon[0] = cosTh;
	float sinTh = sqrt(1.0f - cosTh * cosTh);
	photon[1] = sinTh;
	float phi = 2 * PI * (rando());
	photon[2] = phi;
	float cosPh = cos(phi);
	photon[3] = cosPh;
	float sinPh = sin(phi);
	photon[4] = sinPh;
	//Initializing Position
	float xTotal = 0;
	photon[5] = xTotal;
	float yTotal = 0;
	photon[6] = yTotal;
	float zTotal = 0;
	photon[7] = zTotal;
//Isotropic Scattering of photon off of slab
__device__ void iso_scatt(float *photon){
	float cosTh = (rando() * 2 - 1);
	photon[0] = cosTh;
	float sinTh = sqrt(1 - cosTh * cosTh);
	photon[1] = sinTh;
	photon[2] = phi;
	photon[3] = cosPh;
	photon[4] = sinPh;
//Moments
__device__ void moments(float x1, float y1, float z1, float x2, float y2, float z2, float cosTh, int nLevel,
	float *jPlus, float *hPlus, float *kPlus, float *jMinus, float *kMinus, float *hMinus){
	int l1, l2;
	if (z1 > 0 && z2 > 0 && floor(z1 * nLevel) == floor(z2 * nLevel)){
		return;
	if (cosTh > 0){
		if (z1 <= 0){
			l1 = 1;
		else{
			l1 = z1 * nLevel + 2;
		if (z2 >= 1){
			l2 = nLevel + 1;
		else{
			l2 = z2 * nLevel + 1;
		for (int n = l1 - 1; n < l2; n++){
			atomicAdd(&jPlus[n], 1.0f / cosTh);
			atomicAdd(&hPlus[n], 1.0f);
			atomicAdd(&kPlus[n], cosTh);
	else if (cosTh < 0){
		l1 = (z1 * nLevel) + 1;
		if (z2 < 0) {
			l2 = 1;
		else {
			l2 = (z2 * nLevel) + 2;
		for (int n = l2 - 1; n < l1; n++) {
			//__syncthreads();
			atomicAdd(&jMinus[n], 1.0f / (abs(cosTh)));
			atomicAdd(&hMinus[n], -1.0f);
			atomicAdd(&kMinus[n], abs(cosTh));
//Generates photons and allows them to propagate from the origin
__global__ void work(float *hPlus, float *kPlus, float *jMinus, float *kMinus, float *hMinus,
	float *jPlus, int muBins, float *energy, int nLevel, float *erri,
	float tauMax, int albedo, int seed, int *test){
    //initialization of photon
	float photon[8] = { 0 };
    //atomic adder test
	atomicAdd(&test[0], 1);
    //Generate a new photon when it's z2 position is less than 0
    newP:
	new_photon(photon);
	int aFlag = 0;
	while ((photon[7] >= 0) && (photon[7] <= 1)){
		float x1 = photon[5];
		float y1 = photon[6];
		float z1 = photon[7];
		float tau = -log(rando());
		float s = tau / tauMax;
		photon[5] = photon[5] + s*photon[1] * photon[3];
		photon[6] = photon[6] + s*photon[1] * photon[4];
		photon[7] = photon[7] + s*photon[0];
		float x2 = photon[5];
		float y2 = photon[6];
		float z2 = photon[7];
		moments(x1, y1, z1, x2, y2, z2, photon[0], nLevel,
			jPlus, hPlus, kPlus, jMinus, kMinus, hMinus);
		if ((photon[7] < 0) || (photon[7] > 1))
			continue;
		if (rando()< albedo)
			iso_scatt(photon);
		else{
		aFlag = 1;
		continue;
	if (photon[7] < 0){
		goto newP;
	if (aFlag == 0){
		int l = int(muBins*photon[0]);
		atomicAdd(&erri[l], 1.0f);
		atomicAdd(&energy[l], 1.0f);
//Output
void output(float hPlus[], float kPlus[], float jMinus[], float kMinus[], float hMinus[], float jPlus[],
	int nPhotons, int muBins, float intensity[], float energy[], float nLevel, float sigmai[], float theta[], float erri[])
	//setting values for arrays
	for (int n = 0; n < muBins; n++){
		intensity[n] = energy[n] / (2 * nPhotons*cos(theta[n] * PI / 180))*muBins;
		sigmai[n] = sqrt(erri[n]) / nPhotons;
		energy[n] = energy[n] / nPhotons;
	for (int n = 0; n < nLevel; n++){
		jPlus[n] = jPlus[n] / nPhotons;
		jMinus[n] = jMinus[n] / nPhotons;
		hPlus[n] = hPlus[n] / nPhotons;
		hMinus[n] = hMinus[n] / nPhotons;
		kPlus[n] = kPlus[n] / nPhotons;
		kMinus[n] = kMinus[n] / nPhotons;
	// write output to file: "intensity.dat"
	ofstream file;
	file.open("intensity.dat");
	for (int i = muBins - 1; i > -1; i--) {
		file << theta[i] << "\t" << energy[i] << "\t" << sigmai[i] << "\t" << intensity[i] << "\n";
	file.close();
	// write output to file: "moments.dat"
	ofstream file2;
	file2.open("moments.dat");
	for (int i = 0; i <= nLevel; i++) {
		file2 << jPlus[i] << "\t" << jMinus[i] << "\t" << hPlus[i] << "\t" << hMinus[i] << "\t" << kPlus[i] << "\t" << kMinus[i] << "\n";
	file2.close();
int main()
	//Follow particles through simulation
	//Call all functions
	//Read in parameter file
	//creation of host variables
	int numPhotons;
	cout << "Give an nPhotons value: " << endl;
	cin >> numPhotons;
	const int nPhotons = numPhotons;
    const int muBins = 10;
	const int nmu = 20;
	int nLevel = 10;
	const int nLev = 21;
	float tauMax = 10;
	int albedo = 1;
	float dTheta = float(1) / float(muBins);
    float theta[muBins] = {0};
	float halfW = 0.5 * dTheta;
    float intensity[nmu] = { 0 };
	float sigmai[nmu] = { 0 };
	float *energy;
	float *erri;
	float *jPlus;
	float *jMinus;
	float *hPlus;
	float *hMinus;
	float *kPlus;
	float *kMinus;
	int *test;
    //initialization of dtheta
    for( int i = 0; i < muBins; i++){
        theta[i] = acos(float(i)*dTheta + halfW)* 180/PI;
	//initialization of host memory
	hPlus = (float*)malloc(nLev * sizeof(float));
	jPlus = (float*)malloc(nLev * sizeof(float));
	kPlus = (float*)malloc(nLev * sizeof(float));
	hMinus = (float*)malloc(nLev * sizeof(float));
	jMinus = (float*)malloc(nLev * sizeof(float));
	kMinus = (float*)malloc(nLev * sizeof(float));
	energy = (float*)malloc(nmu * sizeof(int));
	erri = (float*)malloc(nmu * sizeof(int));
	test = (int*)malloc(sizeof(int));
    //Creation of device variables
	float *d_hPlus;
	float *d_kPlus;
	float *d_jMinus;
	float *d_kMinus;
	float *d_hMinus;
	float *d_jPlus;
	float *d_energy;
	float *d_erri;
	int *d_test;
    //Initialization of device memory
	cudaMalloc((void**)&d_hPlus, nLev * sizeof(float));
	cudaMalloc((void**)&d_jPlus, nLev * sizeof(float));
	cudaMalloc((void**)&d_kPlus, nLev * sizeof(float));
	cudaMalloc((void**)&d_hMinus, nLev * sizeof(float));
	cudaMalloc((void**)&d_jMinus, nLev * sizeof(float));
	cudaMalloc((void**)&d_kMinus, nLev * sizeof(float));
	cudaMalloc((void**)&d_energy, nmu * sizeof(float));
	cudaMalloc((void**)&d_erri, nmu * sizeof(float));
	cudaMalloc((void**)&d_test, sizeof(int));
    //Setting device memory to 0
	cudaMemset(d_hPlus, 0, nLev * sizeof(float));
	cudaMemset(d_jPlus, 0, nLev * sizeof(float));
	cudaMemset(d_kPlus, 0, nLev * sizeof(float));
	cudaMemset(d_hMinus, 0, nLev * sizeof(float));
	cudaMemset(d_jMinus, 0, nLev * sizeof(float));
	cudaMemset(d_kMinus, 0, nLev * sizeof(float));
	cudaMemset(d_energy, 0, nmu * sizeof(float));
	cudaMemset(d_erri, 0, nmu * sizeof(float));
	cudaMemset(d_test, 0, sizeof(int));
	int seed = static_cast<unsigned int>(time(0));
	work << <nPhotons / 512, 512 >> >(d_hPlus, d_kPlus, d_jMinus, d_kMinus, d_hMinus, d_jPlus,
		muBins, d_energy, nLevel, d_erri, tauMax, albedo, seed, d_test);
	cudaError_t err = cudaGetLastError();
	if (err != cudaSuccess)
		printf("Error: %s\n", cudaGetErrorString(err));
	cudaMemcpy(hPlus, d_hPlus, nLev * sizeof(float), cudaMemcpyDeviceToHost);
	cudaMemcpy(jPlus, d_jPlus, nLev * sizeof(float), cudaMemcpyDeviceToHost);
	cudaMemcpy(kPlus, d_kPlus, nLev * sizeof(float), cudaMemcpyDeviceToHost);
	cudaMemcpy(hMinus, d_hMinus, nLev * sizeof(float), cudaMemcpyDeviceToHost);
	cudaMemcpy(jMinus, d_jMinus, nLev * sizeof(float), cudaMemcpyDeviceToHost);
	cudaMemcpy(kMinus, d_kMinus, nLev * sizeof(float), cudaMemcpyDeviceToHost);
	cudaMemcpy(energy, d_energy, nmu * sizeof(float), cudaMemcpyDeviceToHost);
	cudaMemcpy(erri, d_erri, nmu * sizeof(float), cudaMemcpyDeviceToHost);
	cudaMemcpy(test, d_test, sizeof(int), cudaMemcpyDeviceToHost);
	for (int i = 0; i < 10; i++) {
		cout << erri[i] << endl;
	printf("Test is %d", test[0]);
	output(hPlus, kPlus, jMinus, kMinus, hMinus, jPlus, nPhotons, muBins, intensity, energy, nLevel, sigmai, theta, erri);
	cudaFree(d_hPlus);
	cudaFree(d_jPlus);
	cudaFree(d_kPlus);
	cudaFree(d_hMinus);
	cudaFree(d_jMinus);
	cudaFree(d_kMinus);
	cudaFree(d_energy);
	cudaFree(d_erri);
    cudaFree(d_test);
	return 0;
Hi, longzc
I can not reproduce your problem. I build your code and execute. Also cuda-memcheck no error found.
Please update your graphic driver and have a try again.
root@devtools-qa36:~# ./x
100000
516
1746
3331
5238
7535
9930
12676
15853
19695
23320
Test is 99840
If you still met the issue, please tell me your
  1. cuda toolkit version
  2. cuda driver version
  3. GPU
  4. OS
  5. command to build the app
I build with nvcc arch-sm_60 kernel.cu, cuda 8.0, my drivers are current 388.81, windows. I did figure out one of the issues, for some reason curand_init(clock64(), threadIdx.x, 0, &state); does not like threadIdx.x I am having no issues with crashing once I switched this to 0. This makes the code run fine, but cuda-memcheck still doesn’t work properly.
Hi, longzc
Glad to see the sample works now.
As to cuda-memcheck on windows, there is known performance issues and we are working on it.
Sorry for the inconvenience caused.
