I run successfully deepstream-audio sample app via below command:
$/opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-audio/deepstream-audio -c configs/ds_audio_sonyc_test_config.txt
In main function of other deepstream app (written by C++), I create a thread to run deepstream-audio command above and then get output using popen() funtion, but when I run deepstream app, one thread of deepstream-audio was created but deepstream-audio not run and shown error like below logs.
Could you help me to fix it?
Thank you very much.
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1.1
• TensorRT Version 8.6
• Issue Type( questions, new requirements, bugs) questions/bugs
**logs
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input.1 1x635x128
1 OUTPUT kFLOAT output1 31
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
**PERF AUDIO: FPS 0 (Avg)
**PERF AUDIO: 0.00 (0.00)
** INFO: <bus_callback:137>: Pipeline ready
** INFO: <bus_callback:123>: Pipeline running
0:00:07.094467074 93942 0xaaaaab343d20 WARN audio-resampler audio-resampler.c:274:convert_taps_gint16_c: can’t find exact taps
0:00:07.095130611 93942 0xaaaaab343d20 WARN nvstreammux gstnvstreammux.cpp:1051:configure_module:<src_bin_muxer> No config-file provided; falling back to default streammux config 1
--------- Audio Thread End—
deepstream-audio was stoped and deepstream-app still continues to run.
