I get this error when running deepstream to receive RTSP on Jetson.
Note: I’m running from an external SSD on Jetson nano
Using winsys: x11
ERROR: Deserialize engine failed because file path: /home/moon/Downloads/deepstream_python_apps-master/apps/deepstream-test3/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:02.161110620 12341 0x40e82a40 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 1]: deserialize engine from file :/home/moon/Downloads/deepstream_python_apps-master/apps/deepstream-test3/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:02.161898396 12341 0x40e82a40 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 1]: deserialize backend context from engine from file :/home/moon/Downloads/deepstream_python_apps-master/apps/deepstream-test3/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:02.161936314 12341 0x40e82a40 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
ERROR: Cannot access prototxt file ‘/home/moon/Downloads/deepstream_python_apps-master/apps/deepstream-test3/…/…/…/…/samples/models/Primary_Detector_Nano/resnet10.prototxt’
ERROR: failed to build network since parsing model errors.
ERROR: failed to build network.
0:00:02.162730235 12341 0x40e82a40 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1735> [UID = 1]: build engine file failed
0:00:02.162764403 12341 0x40e82a40 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1821> [UID = 1]: build backend context failed
0:00:02.162793935 12341 0x40e82a40 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1148> [UID = 1]: generate backend failed, check config file settings
0:00:02.162854404 12341 0x40e82a40 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:02.162878311 12341 0x40e82a40 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start: error: Config file path: dstest3_pgie_config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Error: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(809): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
Exiting app
