Hardware Platform (Jetson / GPU)
Jetson NX
• DeepStream Version
5.1
4.5-b129
• TensorRT Version
7.1.3
After setting
export DISPLAY=:0 or 1
xrandr
got
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 510mm x 290mm
1920x1080 60.00*+ 59.95
1440x900 59.89
1280x1024 60.00
1280x800 59.81
1152x864 75.00
1024x768 70.07 60.01
800x600 60.32 56.25
720x400 70.04
640x480 67.06 59.94
DP-0 disconnected (normal left inverted right x axis y axis)
it seems correct.
Then I tried to run --net=my-net
sudo docker run -it --rm --net=my-net03_default --runtime nvidia --device=/dev/video0:/dev/video0 -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-5.1 -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream-l4t:5.1-21.02-samples
Here is the docker network
docker network ls
NETWORK ID NAME DRIVER SCOPE
e3f32f59cafa bridge bridge local
5a6f24359b00 host host local
e5f39685296f my-net01_default bridge local
e1dc5d5f0fed my-net02 bridge local
2a666b3a6d39 my-net03_default bridge local
317eb9706394 none null local
then when I tried to run test4 app
deepstream-test4-app -i /opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_720p.h264 -p /opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_kafka_proto.so --conn-str="172.21.0.1;9092" --topic=topic01 -s 0
got error
nvbuf_utils: Could not get EGL display connection
One element could not be created. Exiting.
If I set --net=host , all works. But when I need to change to another docker network, it’ll cause the error (I want to make this container can communicate with others, that why I want to try to change the --net, even I will change --net to overlay network type)
Is there any comment on this?
