After successfully trying out the two main Isaac SIM examples I decided to try the Ball Segmentation example as described here.
https://docs.nvidia.com/isaac/isaac/packages/ml/ml.html#ball-seg-chapter
But, I’m getting a “ModuleNotFoundError: No module named ‘scipy’” error for Step 5.
Here is a complete log of the command execution. Note - This is when I tried it a second time after confirming that scipy was installed by going into python (from the same environment), and simply trying import scipy. That worked just fine.
(tf-gpu) mechamj@VisioComputer:~/isaac_sdk-2019.1-17919$ bazel run apps/samples/ball_segmentation/training
WARNING: /home/mechamj/isaac_sdk-2019.1-17919/packages/viewers/BUILD:14:12: in srcs attribute of cc_binary rule //packages/viewers:libviewers_module.so: please do not import ‘//packages_x86_64/viewers:libviewers_module.so’ directly. You should either move the file to this package or depend on an appropriate rule there
WARNING: /home/mechamj/isaac_sdk-2019.1-17919/packages/perception/BUILD:34:12: in srcs attribute of cc_binary rule //packages/perception:libperception_module.so: please do not import ‘//packages_x86_64/perception:libperception_module.so’ directly. You should either move the file to this package or depend on an appropriate rule there
INFO: Analysed target //apps/samples/ball_segmentation:training (1 packages loaded, 2 targets configured).
INFO: Found 1 target…
Target //apps/samples/ball_segmentation:training up-to-date:
bazel-bin/apps/samples/ball_segmentation/training
INFO: Elapsed time: 109.560s, Critical Path: 48.67s, Remote (0.00% of the time): [queue: 0.00%, setup: 0.00%, process: 0.00%]
INFO: 664 processes: 664 linux-sandbox.
INFO: Build completed successfully, 669 total actions
File “/home/mechamj/.cache/bazel/_bazel_mechamj/c922fe759bc372a6bb8e809d110f9870/execroot/isaac/bazel-out/k8-opt/bin/apps/samples/ball_segmentation/training.runfiles/isaac/apps/samples/ball_segmentation/training.py”, line 19, in
import scipy
