I’m trying to compile the CUDA samples on VS2019.
I opened the sample2019.svn solution file in visual studio 2019, i had to delete Vulkan to remove an error specific to it, but when i try to buil the solution i still run into :
Error C1060 compiler is out of heap space segmentationTreeThrust
(i have way more space than vs could use, and 32 gigs of RAM)
and also, more important :
Severity Code Description Project File Line Suppression State
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.0\bin\nvcc.exe” -gencode=arch=compute_35,code="sm_35,compute_35" -gencode=arch=compute_37,code="sm_37,compute_37" -gencode=arch=compute_50,code="sm_50,compute_50" -gencode=arch=compute_52,code="sm_52,compute_52" -gencode=arch=compute_60,code="sm_60,compute_60" -gencode=arch=compute_61,code="sm_61,compute_61" -gencode=arch=compute_70,code="sm_70,compute_70" -gencode=arch=compute_75,code="sm_75,compute_75" -gencode=arch=compute_80,code="sm_80,compute_80" --use-local-env -ccbin “C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.27.29110\bin\HostX86\x64” -x cu -I./ -I…/…/common/inc -I./ -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.0/include” -I…/…/common/inc -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.0\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -Xcompiler “/wd 4819” -g -DWIN32 -DWIN32 -D_MBCS -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Fdx64/Debug/vc142.pdb /FS /Zi /RTC1 /MTd " -o x64/Debug/segmentationTree.cu.obj “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v11.0\6_Advanced\segmentationTreeThrust\segmentationTree.cu”” exited with code 2. segmentationTreeThrust C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Microsoft\VC\v160\BuildCustomizations\CUDA 11.0.targets 772
what can i do ?
Thank you.
