I’m having the following error when a tried to compile grid_map_core ros package in the NVIDIA AGX using Jetpack 4.6.
catkin_make install -j1 -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=/home/nvidia/workspace/install -DCATKIN_WHITELIST_PACKAGES=“grid_map_core” -DCMAKE_C_COMPILER=/usr/bin/gcc-6
Base path: /home/nvidia/workspace
Source space: /home/nvidia/workspace/src
Build space: /home/nvidia/workspace/build
Devel space: /home/nvidia/workspace/devel
Install space: /home/nvidia/workspace/install
Running command: “make cmake_check_build_system” in “/home/nvidia/workspace/build”
Running command: “make install -j1” in “/home/nvidia/workspace/build”
Scanning dependencies of target grid_map_core
[ 6%] Building CXX object grid_map/grid_map_core/CMakeFiles/grid_map_core.dir/src/Polygon.cpp.o
c++: internal compiler error: Segmentation fault (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See file:///usr/share/doc/gcc-6/README.Bugs for instructions.
grid_map/grid_map_core/CMakeFiles/grid_map_core.dir/build.make:158: recipe for target ‘grid_map/grid_map_core/CMakeFiles/grid_map_core.dir/src/Polygon.cpp.o’ failed
make[2]: *** [grid_map/grid_map_core/CMakeFiles/grid_map_core.dir/src/Polygon.cpp.o] Error 4
CMakeFiles/Makefile2:632: recipe for target ‘grid_map/grid_map_core/CMakeFiles/grid_map_core.dir/all’ failed
make[1]: *** [grid_map/grid_map_core/CMakeFiles/grid_map_core.dir/all] Error 2
Makefile:140: recipe for target ‘all’ failed
make: *** [all] Error 2
When i use the jetpack 4.5.1 works. Anybody had the same problem?
