I get the following errors when flashing using Ubuntu 20.04:
19:06:39 ERROR: File System and OS - target_image: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_COMP.tumi.sh; [error]:
19:02:38 INFO: CUDA Runtime - target: Found file /home/tumi/External/sdk_nvidia/nvidia-l4t-cudadebuggingsupport_12.2-33282765.0_arm64.deb with correct checksum, skip downloading.
19:06:39 ERROR: File System and OS - target_image: command terminated with error
19:02:44 INFO: CUDA Runtime - target: verifying checksum of /home/tumi/External/sdk_nvidia/cuda-tegra-repo-ubuntu2204-12-2-local_12.2.12-1_arm64.deb
19:06:39 SUMMARY: File System and OS - target_image: First Error: Installation failed.
19:02:44 INFO: Drivers for Jetson - target_image: verifying checksum of /home/tumi/External/sdk_nvidia/Jetson_Linux_R36.3.0_aarch64.tbz2
19:06:39 SUMMARY: Multimedia API - target: Depends on failed component
19:02:45 INFO: File System and OS - target_image: verifying checksum of /home/tumi/External/sdk_nvidia/Tegra_Linux_Sample-Root-Filesystem_R36.3.0_aarch64.tbz2
19:06:39 SUMMARY: TensorRT Runtime - target: Depends on failed component
19:02:45 INFO: CUDA Runtime - target: verifying checksum of /home/tumi/External/sdk_nvidia/nvidia-l4t-cudadebuggingsupport_12.2-33282765.0_arm64.deb
19:06:39 SUMMARY: CUDA Runtime - target: Depends on failed component
19:02:45 INFO: TensorRT Runtime - target: verifying checksum of /home/tumi/External/sdk_nvidia/nv-tensorrt-local-repo-l4t-8.6.2-cuda-12.2_1.0-1_arm64.deb
19:06:39 SUMMARY: CuDNN Runtime - target: Depends on failed component
19:02:45 INFO: CuDNN Runtime - target: verifying checksum of /home/tumi/External/sdk_nvidia/cudnn-local-tegra-repo-ubuntu2204-8.9.4.25_1.0-1_arm64.deb
19:06:39 SUMMARY: OpenCV Runtime - target: Depends on failed component
19:06:39 SUMMARY: VPI Runtime - target: Depends on failed component
19:06:39 SUMMARY: CuPVA Runtime - target: Depends on failed component
19:06:39 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
19:06:39 SUMMARY: Gstreamer - target: Depends on failed component
19:06:39 SUMMARY: DLA Compiler - target: Depends on failed component
19:06:39 SUMMARY: DateTime Target Setup - target: Depends on failed component
19:06:39 SUMMARY: Flash Jetson Linux - flash: Depends on failed component
SDKM_logs_JetPack_6.0_(rev._2)_Linux_for_Jetson_AGX_Orin_modules_2024-07-10_19-03-17.zip (216.7 KB)
I also get a similar set of errors using WSL with Ubuntu 20.04
