Error when trying to parse Triton output tensor on multistream input
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2
• TensorRT Version 8.5.2.2
• NVIDIA GPU Driver Version (valid for GPU only) 525.85.12
• Issue Type( questions, new requirements, bugs) question
When I am trying to parse my triton custom ensemble model following the deepstream-ssd-parser example , I can do it just fine with one video stream.
However, when i am trying to do the same with multiple stream, I am getting this error.
Please advise on how to parse output tensor from custom ensemble model on multistream input.
could you share the media pipeline? could you share the configuration file? and you might check the nvinferserver code because it is opensource from DS6.2.
infer_config.txt (1.7 KB)
deepstream_pipeline.py (8.7 KB)
@fanzh Here is my pipeline and infer config file.
Previously when it was only a single stream, I managed to parse my triton ensemble output using the output tensor metadata, so I am looking for a similar way to do it with multistream. Thanks in advance
there are a lot of custom code in deepstream_pipeline.py, can you simplify it? and please refer to deepstream_test_3.py, which can accept multiple inputs, you only need to port this code multiple sources
