Hi, I was trying to run gazenet.ipynb, one of the TLT CV Sample WorkFlows, inside the TLT for Video Streaming Analytics container, on the DGX A100 server.
I had a problem with step 3. Generate tfrecords from labels in json format. Any advice on this matter?
!tlt gazenet dataset_convert -folder-suffix pipeline
-norm_folder_name Norm_Data
-sets p01-day03
-data_root_path $DATA_DOWNLOAD_DIR/MPIIFaceGaze/sample-dataset
File “/usr/local/lib/python3.6/dist-packages/urllib3/connectionpool.py”, line 677, in urlopen
chunked=chunked,
File “/usr/local/lib/python3.6/dist-packages/urllib3/connectionpool.py”, line 392, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/usr/lib/python3.6/http/client.py”, line 1272, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/lib/python3.6/http/client.py”, line 1318, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/lib/python3.6/http/client.py”, line 1267, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.6/http/client.py”, line 1038, in _send_output
self.send(msg)
File “/usr/lib/python3.6/http/client.py”, line 976, in send
self.connect()
File “/usr/local/lib/python3.6/dist-packages/docker/transport/unixconn.py”, line 43, in connect
sock.connect(self.unix_socket)
FileNotFoundError: [Errno 2] No such file or directory
During handling of the above exception, another exception occurred:
File “/usr/local/lib/python3.6/dist-packages/requests/adapters.py”, line 449, in send
timeout=timeout
File “/usr/local/lib/python3.6/dist-packages/urllib3/connectionpool.py”, line 727, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File “/usr/local/lib/python3.6/dist-packages/urllib3/util/retry.py”, line 403, in increment
raise six.reraise(type(error), error, _stacktrace)
File “/usr/local/lib/python3.6/dist-packages/urllib3/packages/six.py”, line 734, in reraise
raise value.with_traceback(tb)
chunked=chunked,
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’))
File “/usr/local/lib/python3.6/dist-packages/docker/api/client.py”, line 205, in _retrieve_server_version
return self.version(api_version=False)[“ApiVersion”]
File “/usr/local/lib/python3.6/dist-packages/docker/api/daemon.py”, line 181, in version
return self._result(self._get(url), json=True)
File “/usr/local/lib/python3.6/dist-packages/docker/utils/decorators.py”, line 46, in inner
return f(self, *args, **kwargs)
File “/usr/local/lib/python3.6/dist-packages/docker/api/client.py”, line 228, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File “/usr/local/lib/python3.6/dist-packages/requests/sessions.py”, line 543, in get
return self.request(‘GET’, url, **kwargs)
File “/usr/local/lib/python3.6/dist-packages/requests/sessions.py”, line 530, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.6/dist-packages/requests/sessions.py”, line 643, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.6/dist-packages/requests/adapters.py”, line 498, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’))
File “/usr/local/bin/tlt”, line 8, in
sys.exit(main())
File “/usr/local/lib/python3.6/dist-packages/tlt/entrypoint/entrypoint.py”, line 114, in main
args[1:]
File “/usr/local/lib/python3.6/dist-packages/tlt/components/instance_handler/local_instance.py”, line 250, in launch_command
docker_handler = self.handler_map[
File “/usr/local/lib/python3.6/dist-packages/tlt/components/instance_handler/local_instance.py”, line 107, in handler_map
docker_digest=map_val.docker_digest
File “/usr/local/lib/python3.6/dist-packages/tlt/components/docker_handler/docker_handler.py”, line 44, in init
self._docker_client = docker.from_env()
File “/usr/local/lib/python3.6/dist-packages/docker/client.py”, line 85, in from_env
timeout=timeout, version=version, **kwargs_from_env(**kwargs)
File “/usr/local/lib/python3.6/dist-packages/docker/client.py”, line 40, in init
self.api = APIClient(*args, **kwargs)
File “/usr/local/lib/python3.6/dist-packages/docker/api/client.py”, line 188, in init
self._version = self._retrieve_server_version()
File “/usr/local/lib/python3.6/dist-packages/docker/api/client.py”, line 213, in _retrieve_server_version
‘Error while fetching server API version: {0}’.format(e)
docker.errors.DockerException: Error while fetching server API version: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’))
