I get the following warning whenever one of your packages is upgraded:
Warning: could not open file ‘/usr/share/applications/vpi1_demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/demos/nvidia-vpi_demo_remap-1.0.desktop’ – Too many levels of symbolic links
Things work just fine, but I thought you may be interested in looking into a fix.
As shown in the warning message, the “demos” file is a symbolic link which points to the folder where it resides:
$ ls -l /usr/share/applications/vpi1_demos/demos
lrwxrwxrwx 1 root root 41 Feb 28 2021 /usr/share/applications/vpi1_demos/demos -> /opt/nvidia/vpi1/share/applications/demos
I do not know exactly which package generated the error, but here the list of packages that were updated:
The following packages will be upgraded:
bind9-host ghostscript ghostscript-x isc-dhcp-client isc-dhcp-common isc-dhcp-server libasn1-8-heimdal libbind9-160
libdns-export1100 libdns1100 libgmp10 libgs9 libgs9-common libgssapi3-heimdal libhcrypto4-heimdal libheimbase1-heimdal
libheimntlm0-heimdal libhx509-5-heimdal libirs-export160 libisc-export169 libisc169 libisccc160 libisccfg-export160 libisccfg160
libjpeg-turbo8 libjpeg-turbo8-dev libkrb5-26-heimdal liblwres160 libroken18-heimdal libtiff-dev libtiff5 libtiff5-dev libtiffxx5
libwind0-heimdal linux-libc-dev python3-mako thunderbird thunderbird-gnome-support unzip
39 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I’m attaching the whole dist-upgrade
command output.
20221015-upgrade.txt (15.5 KB)
As I said above, it worked just fine so I’m not in need of any help on this one. It’s just for you guys to have a chance to fix a small issue.
