The jetbot was having an issue with slow framrates, so I tried to use the zmq camera fix, however it gives the following Error:
ModuleNotFoundError Traceback (most recent call last)
<ipython-input-4-7eaed894edf3> in <module>
----> 1 from jetbot.camera.zmq_camera import ZmqCamera
2
3 camera = ZmqCamera() # this should have same interface as current camera
ModuleNotFoundError: No module named 'jetbot.camera.zmq_camera'; 'jetbot.camera' is not a package
I cloned the repo and started the publisher just fine. It gives the following output:
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
I can manually see the zmq_camera.py file in /jetbot/scripts, so it should have cloned the correct repo.
What could be causing this issue?
Software:
the sd card image based on jetpack 4.3, as it’s the newest one, where object detection actually works.
