Error while adding and deleting RTSP sources
• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: nvcr.io/nvidia/deepstream:5.1-21.02-samples
Hi everyone, I’m trying to customize adding and deleting sources refer to deepstream_rt_src_add_del.py in deepstream_python_apps.
With rtsp source, when i delete the source and then add another source to that source_id, the return state is NO_PREROLL. It means that the state change succeeded but the element cannot produce data in PAUSED. This typically happens with live sources. As the result, I cannot add a new source to the deleted source_id.
However, with the input sources are video files, it run successfully.
Could you guys help me with this issue ? Here is my code if you need: test_add_delete_source.py (18.2 KB). Thanks in advance !
deepstream_rt_src_add_del.py supports rtsp source too. Can deepstream_rt_src_add_del.py work with your rtsp source?
Well, it can add rtsp sources successfully. But when delete stage happens, it gets error.
