Dear Experts,
Kindly help me with the issues while compiling apache MXNET (incubate) in Windows using Visual Studio 2017, CUDA Toolkit 10.2, and CUDNN. I use CMake to build the Visual Studio 2017 project file, with the following command:
cmake -G "Visual Studio 15 2017 Win64" -T cuda=10.2,host=x64^
-DCMAKE_BUILD_TYPE=Release -DUSE_CUDA=1 -DUSE_CUDNN=1 -DUSE_CPP_PACKAGE=1^
-DUSE_NVRTC=1 -DUSE_OPENCV=1 -DUSE_OPENMP=1 -DUSE_BLAS=open -DUSE_LAPACK=1^
-DUSE_DIST_KVSTORE=0 -DCUDA_ARCH_LIST=Common -DCUDA_TOOLSET=10.2^
-DCUDNN_INCLUDE="C:\cuda\include"^
-DCUDNN_LIBRARY="C:\cuda\lib\x64\cudnn.lib" ..
The Build command was:
msbuild -v:diag mxnet.sln /p:Configuration=Release;Platform=x64 /maxcpucount
When compiling MXNET using NVIDIA libraries encountered the following error:
Command:
“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2\bin\nvcc.exe” -gencode=arch=compute_50,code="sm_50,compute_50" -gencode=arch=compute_50,code="compute_50,compute_50" --use-local-env -ccbin “C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\bin\HostX64\x64” -x cu -I"C:\incubator-mxnet\include" -I"C:\incubator-mxnet\src" -I"C:\incubator-mxnet\3rdparty\nvidia_cub" -I"C:\incubator-mxnet\3rdparty\tvm\nnvm\include" -I"C:\incubator-mxnet\3rdparty\tvm\include" -I"C:\incubator-mxnet\3rdparty\dmlc-core\include" -I"C:\incubator-mxnet\3rdparty\dlpack\include" -I"C:\incubator-mxnet\3rdparty\mshadow" -I"C:\incubator-mxnet\build\3rdparty\dmlc-core\include" -IC:\openblas -IC:\opencv\build\include -IC:\cuda\include -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2\include" --keep-dir x64\Release -maxrregcount=0 --machine 64 --compile -cudart static -Xcompiler=“/EHsc -Ob2 -Gy /bigobj” -D_WINDOWS -DNDEBUG -DDMLC_LOG_FATAL_THROW=1 -DDMLC_MODERN_THREAD_LOCAL=0 -DDMLC_LOG_STACK_TRACE_SIZE=0 -DDMLC_USE_CXX11 -DDMLC_STRICT_CXX11 -DDMLC_USE_CXX14 -DMSHADOW_IN_CXX11 -DWIN32_LEAN_AND_MEAN -D_SCL_SECURE_NO_WARNINGS -D_CRT_SECURE_NO_WARNINGS -DMXNET_EXPORTS -DNNVM_EXPORTS -DNOMINMAX -DMSHADOW_USE_CBLAS=1 -DMSHADOW_USE_MKL=0 -DMXNET_USE_BLAS_OPEN=1 -DMXNET_USE_LIBJPEG_TURBO=0 -DMXNET_USE_OPENCV=1 -DMXNET_USE_OPENMP=1 -DMXNET_USE_LAPACK=1 -DUSE_CUDNN -DMXNET_ENABLE_CUDA_RTC=1 -DMXNET_USE_CUDA=1 -DMXNET_USE_SIGNAL_HANDLER=1 -DMSHADOW_USE_CUDA=1 -DMSHADOW_FORCE_STREAM -DMSHADOW_USE_SSE=0 -DMSHADOW_USE_CUDNN -DMSHADOW_USE_F16C=0 -DMSHADOW_INT64_TENSOR_SIZE=0 -D__USE_XOPEN2K8 -DDMLC_CORE_USE_CMAKE -DDMLC_USE_CXX11=1 -D"CMAKE_INTDIR="Release"" -Dmxnet_50_EXPORTS -DWIN32 -D_WINDOWS -DNDEBUG -DDMLC_LOG_FATAL_THROW=1 -DDMLC_MODERN_THREAD_LOCAL=0 -DDMLC_LOG_STACK_TRACE_SIZE=0 -DDMLC_USE_CXX11 -DDMLC_STRICT_CXX11 -DDMLC_USE_CXX14 -DMSHADOW_IN_CXX11 -DWIN32_LEAN_AND_MEAN -D_SCL_SECURE_NO_WARNINGS -D_CRT_SECURE_NO_WARNINGS -DMXNET_EXPORTS -DNNVM_EXPORTS -DNOMINMAX -DMSHADOW_USE_CBLAS=1 -DMSHADOW_USE_MKL=0 -DMXNET_USE_BLAS_OPEN=1 -DMXNET_USE_LIBJPEG_TURBO=0 -DMXNET_USE_OPENCV=1 -DMXNET_USE_OPENMP=1 -DMXNET_USE_LAPACK=1 -DUSE_CUDNN -DMXNET_ENABLE_CUDA_RTC=1 -DMXNET_USE_CUDA=1 -DMXNET_USE_SIGNAL_HANDLER=1 -DMSHADOW_USE_CUDA=1 -DMSHADOW_FORCE_STREAM -DMSHADOW_USE_SSE=0 -DMSHADOW_USE_CUDNN -DMSHADOW_USE_F16C=0 -DMSHADOW_INT64_TENSOR_SIZE=0 -D__USE_XOPEN2K8 -DDMLC_CORE_USE_CMAKE -DDMLC_USE_CXX11=1 -D"CMAKE_INTDIR="Release"" -Dmxnet_50_EXPORTS -D_WINDLL -D_MBCS -Xcompiler “/EHsc /W3 /nologo /O2 /Fdmxnet_50.dir\Release\vc141.pdb /FS /Zi /MT /GR” -o mxnet_50.dir\Release/src/operator/quantization/quantized_pooling.cu.obj “C:\incubator-mxnet\src\operator\quantization\quantized_pooling.cu”
Errors Message:
c:\incubator-mxnet\include\mshadow./base.h(838): warning: calling a constexpr host function(“max”) from a host device function(“MaxValue”) is not allowed. The experimental flag ‘–expt-relaxed-constexpr’ can be used to allow this.
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2\include\thrust/system/cuda/detail/core/util.h(761): error: expected an identifier
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2\include\thrust/system/cuda/detail/core/util.h(783): error: expected an identifier
C:\incubator-mxnet\3rdparty\tvm\nnvm\include\nnvm/op.h(106): warning: field of class type without a DLL interface used in a class with a DLL interface
C:\incubator-mxnet\3rdparty\tvm\nnvm\include\nnvm/op.h(111): warning: field of class type without a DLL interface used in a class with a DLL interface
C:\incubator-mxnet\3rdparty\tvm\nnvm\include\nnvm/op.h(113): warning: field of class type without a DLL interface used in a class with a DLL interface
C:\incubator-mxnet\3rdparty\tvm\nnvm\include\nnvm/op.h(141): warning: field of class type without a DLL interface used in a class with a DLL interface
C:\incubator-mxnet\3rdparty\tvm\nnvm\include\nnvm/op.h(147): warning: field of class type without a DLL interface used in a class with a DLL interface
C:\incubator-mxnet\3rdparty\tvm\nnvm\include\nnvm/op.h(180): warning: field of class type without a DLL interface used in a class with a DLL interface
c:\incubator-mxnet\3rdparty\tvm\nnvm\include\nnvm\node.h(163): warning: field of class type without a DLL interface used in a class with a DLL interface
c:\incubator-mxnet\3rdparty\tvm\nnvm\include\nnvm\node.h(165): warning: field of class type without a DLL interface used in a class with a DLL interface
c:\incubator-mxnet\3rdparty\tvm\nnvm\include\nnvm\node.h(170): warning: field of class type without a DLL interface used in a class with a DLL interface
c:\incubator-mxnet\3rdparty\tvm\nnvm\include\nnvm\node.h(172): warning: field of class type without a DLL interface used in a class with a DLL interface
C:\incubator-mxnet\3rdparty\tvm\nnvm\include\nnvm/symbolic.h(73): warning: field of class type without a DLL interface used in a class with a DLL interface
2 errors detected in the compilation of “C:/Users/wwidj/AppData/Local/Temp/tmpxft_0000a86c_00000000-7_quantized_pooling.cpp1.ii”.
After investigation, its look like, the Microsoft Visual Studio Compiler (cl.exe) rejected the following codes on NVIDIA CUDA library header:
Both lines pointed to the following codes:
template<class T, size_t N>
struct array
typedef T value_type;
typedef T ref[N];
enum {SIZE = N}; // THIS IS THE LINE 761 AND 783**
private:
T data_[N];
public:
__host__ __device__ T* data() { return data_; }
__host__ __device__ const T* data() const { return data_; }
__host__ __device__ T& operator[](unsigned int idx) { return ((T*)data_)[idx]; }
__host__ __device__ T const& operator[](unsigned int idx) const { return ((T*)data_)[idx]; }
__host__ __device__ unsigned int size() const { return N; }
__host__ __device__ operator ref&() { return data_; }
Kindly help me to figure out the solution to this problem.
Thanks and Best Regards
