Error while converting model using TAO
More, what is your Jetpack version ?
$ apt-cache show nvidia-jetpack
And did you download the correct tao-converter?
my jetpack version is 4.4
I successfully converted the ssd etlt model file, so the tao-converter should be correct
Can you try
$ ./tao-converter -k nvidia_tlt -d 3,544,960 -p Input,1x3x544x960,2x3x544x960,4x3x544x960 -o BatchedNMS -e trt.fp16.engine -t fp16 -i nchw -m 8 yolov4_resnet18.etlt
Same error again,
I will prepare a new jetpack to try
It should not be related to Jetpack version.
On my NX, it is also Jetpack 4.4, it works well against this yolo_v4 etlt model.
Can you show
$ ll /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so*
Can you run
$ md5sum tao-converter
It is different. Mine is
aa79fad3ba09edb086bbbcfc2934c49b tao-converter
Can you try
$ wget https://developer.nvidia.com/cuda102-trt71-jp44-0
then unzip it and chmod +x
ohhhhhhhhhhhhhhh,it works.Thank you very much.
Refer to TensorRT — TAO Toolkit 3.0 documentation
