I have an error on Creating System OS to Jetson Nano Developer Kit when I was tried to flash it. this the logs installation :
05:11:56 INFO: File System and OS - target_image: ||||||||||||||||||||||| ERROR |||||||||||||||||||||||
05:11:56 INFO: File System and OS - target_image: -----------------------------------------------------
05:11:56 INFO: File System and OS - target_image: 1. The root filesystem, provided with this package,
05:11:56 INFO: File System and OS - target_image: has to be extracted to this directory:
05:11:56 INFO: File System and OS - target_image: /media/kasol/Windows-SSD/sdk_target/JetPack_4.6.2_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/rootfs
05:11:56 INFO: File System and OS - target_image: 2. The root filesystem, provided with this package,
05:11:56 INFO: File System and OS - target_image: has to be extracted with ‘sudo’ to this directory:
05:11:56 INFO: File System and OS - target_image: Consult the Development Guide for instructions on
05:11:56 INFO: File System and OS - target_image: extracting and flashing your device.
05:11:56 INFO: File System and OS - target_image: |||||||||||||||||||||||||||||||||||||||||||||||||||||
05:11:56 INFO: File System and OS - target_image: [ Package Install Finished with Error ]
05:11:56 INFO: File System and OS - target_image: [host] [ 2.70 MB used. Disk Avail: 3.51 GB ]
05:11:56 INFO: File System and OS - target_image: [ NV_L4T_FILE_SYSTEM_AND_OS_T210_COMP Install took 6m56s ]
05:11:56 ERROR: File System and OS - target_image: command terminated with error
05:11:56 SUMMARY: File System and OS - target_image: First Error: Installation failed.
How I can fix that?
