Is your ubuntu a native or the virtual machine(e.g VMware…)?
Please press EXPORT LOGS
button for us to review.
I’m using virtual machine(virtual box)
mistake message
11:48:19 ERROR: Flash Jetson Linux - flash: *** Reading ECID … SDKM_INSTALL_ERROR *** Error: ECID read failed.
11:48:19 ERROR: Flash Jetson Linux - flash: Put the target board in RCM mode and retry.
11:48:19 ERROR: Flash Jetson Linux - flash: *** ERROR: Parsing boardid failed
11:48:19 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /home/vboxuser/.nvsdkm/replays/scripts/JetPack_6.2_Linux/NV_L4T_FLASH_JETSON_LINUX_COMP.sh; [error]: *** ERROR: Parsing boardid failed
But I think that I am in the recovery mode
Bus 001 Device 010: ID 0955:7323 NVIDIA Corp. APX
I can provide picture later
Our recommended approach is to use native ubuntu with sdk manager.
Some users share their successful experience in VMware.
Please refer to below link
nox i am at the nexr step
and i face another problem
the message
13:32:10 ERROR: Flash Jetson Linux - flash: sudo: ./nvsdkmanager_flash.sh: command not found
13:32:10 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /home/vboxuser/.nvsdkm/replays/scripts/JetPack_5.1.4_Linux/NV_L4T_FLASH_JETSON_LINUX_COMP.sh; [error]:
13:32:10 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
13:32:10 INFO: Flash Jetson Linux - flash: [host] [ 4.00 KB used. Disk Avail on Partition /dev/sda5: 24.16 GB ]
13:32:10 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 0s ]
13:32:10 ERROR: command error code: 11
13:32:10 ERROR: Flash Jetson Linux - flash: command terminated with error
13:32:10 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
13:32:10 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
13:32:10 SUMMARY: Multimedia API - target: Depends on failed component
13:32:10 SUMMARY: TensorRT on Target - target: Depends on failed component
13:32:10 SUMMARY: TensorRT Runtime - target: Depends on failed component
13:32:10 SUMMARY: VPI on Target - target: Depends on failed component
13:32:10 SUMMARY: VPI Runtime - target: Depends on failed component
13:32:10 SUMMARY: CuPVA Runtime - target: Depends on failed component
13:32:10 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
13:32:10 SUMMARY: CUDA Runtime - target: Depends on failed component
13:32:10 SUMMARY: cuDNN on Target - target: Depends on failed component
13:32:10 SUMMARY: CuDNN Runtime - target: Depends on failed component
13:32:10 SUMMARY: OpenCV - target: Depends on failed component
13:32:10 SUMMARY: OpenCV Runtime - target: Depends on failed component
13:32:10 SUMMARY: DateTime Target Setup - target: Depends on failed component
INSTALLATION FAILEDPlease review the terminal tab for details. Resolve and RETRY.
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2025, NVIDIA CORPORATION. All rights reserved. | NVIDIA Developer
EXPORT LOGS and attach zip file for us to review
It appears that you are using the virtual box.
We recommend to use the bare mental or VMware followed the mentioned topics.
