Error while flashing on Xavier emmc
I am trying to flash to Xavier NX using flash.sh command and I am facing this issue.
(Using xavier-nx board with l4t 32.4.2dp)
[   0.0075 ] Generating RCM messages
[   0.0108 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/xavier_nx/Linux_for_Tegra/Xavier_NX/bootloader/mb1_t194_prod.bin zerosbk
[   0.0123 ] Header already present for /home/xavier_nx/Linux_for_Tegra/Xavier_NX/bootloader/mb1_t194_prod.bin
[   0.0194 ]
[   0.0228 ] tegrasign_v2 --key None --getmode mode.txt
[   0.0260 ] Assuming zero filled SBK key
[   0.0284 ]
[   0.0302 ] tegrasign_v2 --key None --file /home/xavier_nx/Linux_for_Tegra/Xavier_NX/bootloader/mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[   0.0316 ] Assuming zero filled SBK key
[   0.0327 ]
[   0.0368 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/xavier_nx/Linux_for_Tegra/Xavier_NX/bootloader/mb1_t194_prod_sigheader.bin /home/xavier_nx/Linux_for_Tegra/Xavier_NX/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[   0.0473 ]
[   0.0517 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[   0.0569 ]
[   0.0585 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/xavier_nx/Linux_for_Tegra/Xavier_NX/bootloader/mb1_t194_prod_sigheader.bin 0 0
[   0.0603 ] RCM 0 is saved as rcm_0.rcm
[   0.0682 ] RCM 1 is saved as rcm_1.rcm
[   0.0682 ] RCM 2 is saved as rcm_2.rcm
[   0.0682 ] List of rcm files are saved in rcm_list.xml
[   0.0682 ]
[   0.0682 ] Signing RCM messages
[   0.0748 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[   0.0776 ] Assuming zero filled SBK key
[   0.0790 ]
[   0.0791 ] Copying signature to RCM mesages
[   0.0807 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0856 ]
[   0.0859 ] Boot Rom communication
[   0.0891 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[   0.0910 ] RCM version 0X190001
[   0.0925 ] Boot Rom communication completed
[   1.1077 ]
[   2.1156 ] tegrarcm_v2 --isapplet
[   2.1210 ] Applet version 01.00.0000
[   2.1406 ]
[   2.1475 ] tegrarcm_v2 --ismb2
[   2.1732 ]
[   2.1804 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[   2.1869 ]
[   2.1943 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[   2.2004 ] adding BCH for nvtboot_applet_t194.bin
[   2.2115 ]
[   2.2153 ] tegrasign_v2 --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   2.2199 ] Assuming zero filled SBK key
[   2.2200 ]
[   2.2270 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[   2.2318 ]
[   2.2353 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[   2.2378 ] Applet version 01.00.0000
[   2.2559 ] Sending mb2
[   2.2561 ] [................................................] 100%
[   2.2691 ]
[   2.2743 ] tegrarcm_v2 --boot recovery
[   2.2795 ] Applet version 01.00.0000
[   2.3008 ]
[   3.3075 ] tegrarcm_v2 --isapplet
[   3.3340 ]
[   3.3401 ] tegrarcm_v2 --ismb2
[   3.3475 ] MB2 Applet version 01.00.0000
[   3.3700 ]
[   3.3772 ] tegrarcm_v2 --ismb2
[   3.3836 ] MB2 Applet version 01.00.0000
[   3.4010 ]
[   3.4060 ] Retrieving EEPROM data
[   3.4068 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/xaiver_nx/Linux_for_Tegra/Xavier_NX/bootloader/cvm.bin
[   3.4122 ] MB2 Applet version 01.00.0000
[   3.4318 ] 000000003636002a: E> I2C: Timeout while polling for bus clear. Last value 0x00000000.
[   3.4842 ]
[   3.4842 ]
[   3.4922 ] tegradevflash_v2 --oem platformdetails eeprom cvm /home/xavier_nx/Linux_for_Tegra/Xavier_NX/bootloader/cvm.bin
[   3.4975 ] CPU Bootloader is not running on device.
[   3.5021 ]
Error: Return value 4
Command tegradevflash_v2 --oem platformdetails eeprom cvm /home/xavier_nx/Linux_for_Tegra/Xavier_NX/bootloader/cvm.bin
Reading board information failed.
How can I fix this?
Ashik P
Can you say more about the host PC? Is it a VM?
Are you sure the Jetson was in recovery mode, and were you using the supplied micro-B USB cable? Also, is this a developer kit or is it an eMMC model?
hello ashik.p,
could you please get the latest NVIDIA JetPack SDK, JetPack-4.5 is the latest production release, supporting all Jetson modules.
thanks
I am not using VM, I tried flashing from my ubuntu host PC.
Its an emmc board and yes the board was in recovery mode. I am able to flash to my other emmc som with the same hardware setup.
So I doubt something wrong with the xavier-nx som am using.
You might try a non-developer-preview release. “Developer preview” is what the “dp” of “32.4.2dp” is. I’m sure one of the reasons @JerryChang mentioned using a current release is that the developer preview might not be entirely complete. Are you able to use a more recent release?
