Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.2.10884
other
Host Machine Version
other
Hi am trying to following *
Install DRIVE OS Linux Debian Packages
and trying to use bootburn.py script . I encounter the following issues
drive/drive-foundation# tools/flashtools/bootburn/bootburn.py -b p3710-10-a01 -B qspi
****** Starting bootburn/bootburn.py ********
********* Starting t23x bootburn py ********
Bootburn Starting with arguments [‘tools/flashtools/bootburn/bootburn.py’, ‘-b’, ‘p3710-10-a01’, ‘-B’, ‘qspi’]
cwd in setBoardConfigPath :: /drive/drive-foundation/tools/flashtools/bootburn_t23x_py
trying hardware folder:
/drive/drive-foundation/platform-config/hardware/nvidia/platform/t23x/automotive/flashing/board_configs
cwd in loadBoardGoldenRegsFile :: /drive/drive-foundation/tools/flashtools/bootburn_t23x_py
Default Schema:/drive/drive-foundation/tools/flashtools/bootburn_t23x_py/nv-customer-data-schema.json
Check finished successfully
Done parsing command line
[bootburn]: [getListTargetsInRecovery(3955)] : Bus 001 Device 010: ID 0955:7023 NVIDIA Corp. APX
[bootburn]: [getListTargetsInRecovery(3955)] : Bus 001 Device 004: ID 0955:7045 NVIDIA Corp.
p3710-10-a01
*** found bootburn-flags in platform-config.json ****
[bootburnTegra-A]: [GetTargetECID(792)] : Target BR_CID: 0x80012344705DD5047400000007000240
[bootburnTegra-A]: [GetTargetECID(793)] : Target ECID: 0x4705DD5047400000007000240
[bootburnTegra-A]: [CheckFuseForAuthentication(810)] : Target Authentication State : SHA-2
[bootburnTegra-A]: [GenAdbSerialNum(558)] : ADB serial number is 8S2TQK278000003G00I0
[bootburnTegra-A]: [CheckForDeviceType(908)] : Detected ES production device type
*** in targetConfig, s_BrickOnTCFFlashingFail not found in board_config ***
*** in targetConfig, s_BrickOnFirmwareFlashingFail not found in board_config ***
[bootburnTegra-A]: creating and flashing coldboot images
[bootburnTegra-A]: [Boot_Create_Flash_Coldboot(730)] : Creating & Flashing images
[bootburnTegra-A]: Creating rcm-flash images
[bootburnTegra-A]: [Boot_Create_Flash_Coldboot(733)] : flashingCFG :: /drive/drive-foundation/tools/flashtools/flashing_kernel/flashing_configs/t23x/quickboot_flashing.cfgself.targetConfig.p_OutDirPath :: /drive/drive-foundation/tools/flashtools/bootburn_t23x_py/__temp_t234/Tegra-A-49511082225
[bootburnTegra-A]: [GenerateImage(2430)] : Generating Flashing-RCM Images
[bootburnTegra-A]: [Boot_Create_Flash_Coldboot(737)] : Generating cold boot flash-images
command line used was:
Linux dtb File not found – /drive/drive-foundation/virtualization/hypervisor/t23x/configs/t234ref-release/pct/p3710-10-a01/linux/tegra234-p3710-0010-a01-linux-driveav-gos.dtb
Exception 74 raised in bootburn_active
File “/drive/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn.py”, line 156, in bootburn_active
bootburnOrin.Boot_Create_Flash_Coldboot()
File “/drive/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn_orin.py”, line 739, in Boot_Create_Flash_Coldboot
self.CreateVDKImages(self.targetConfig.f_FlashCfg, self.targetConfig.p_OutDirPath, “flash-images”)
File “/drive/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn_orin.py”, line 333, in CreateVDKImages
self.GenerateImage(self.storageCfgParser.cfgFileList, l_Operation, operationPath)
File “/drive/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn_lib.py”, line 2394, in GenerateImage
self.CopyAndPreprocessDceBinary(l_Image, p_TempDumpPath)
File “/drive/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn_orin.py”, line 266, in CopyAndPreprocessDceBinary
AbnormalTermination("Linux dtb File not found – " + linuxFileName, nverror.NvError_FileNotFound)
File “/drive/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/flashtools_nverror.py”, line 249, in AbnormalTermination
raise OSError(errorCode)
OSError: 74
root@6.0.6.0-0004-build-linux-sdk:/drive/drive-foundation#
any reasons why i see this error .
