Hi Guys, whenever I import from tf.transformations import euler_from_quaternion
I am getting the following error -
type or pastTraceback (most recent call last):
File "/home/nilesh/isaac_sim/scripts/main/launcher.py", line 14, in <module>
from sim_handler import *
File "/home/nilesh/isaac_sim/scripts/main/sim_handler.py", line 35, in <module>
File "/home/nilesh/isaac_sim/ros_utils/devel/lib/python3/dist-packages/tf/__init__.py", line 34, in <module>
exec(__fh.read())
File "<string>", line 30, in <module>
File "/opt/ros/noetic/lib/python3/dist-packages/tf2_ros/__init__.py", line 38, in <module>
from tf2_py import *
File "/opt/ros/noetic/lib/python3/dist-packages/tf2_py/__init__.py", line 38, in <module>
from ._tf2 import *
ImportError: /opt/ros/noetic/lib/python3/dist-packages/tf2_py/_tf2.so: undefined symbol: _ZNK3tf210BufferCore12_frameExistsERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE
./python.sh: line 40: 85566 Segmentation fault (core dumped) $python_exe "$@" $args
There was an error running python
e code here
Regards,
Nilesh
