Error while inferencing yolov5 tensorrt version on Jetson Xavier NX
Getting this error while running weight.engine for yolov5
command - sudo python3 detect.py --weights best_device0_640x480.engine --imgsz 640 480 --source car.jpg
Tensorrt version - 8.0.1
torch - 1.10.1
torchvision - 0.11.2
NGC container - l4t-tensorrt:r8.0.1-runtime
Loading best_device0_640x480.engine for TensorRT inference…
[TensorRT] INFO: [MemUsageChange] Init CUDA: CPU +353, GPU +0, now: CPU 441, GPU 3790 (MiB)
[TensorRT] INFO: Loaded engine size: 171 MB
[TensorRT] INFO: [MemUsageSnapshot] deserializeCudaEngine begin: CPU 612 MiB, GPU 3961 MiB
[TensorRT] ERROR: 1: [stdArchiveReader.cpp::StdArchiveReader::34] Error Code 1: Serialization (Serialization assertion safeVersionRead == safeSerializationVersion failed.Version tag does not match. Note: Current Version: 43, Serialized Engine Version: 0)
[TensorRT] ERROR: 4: [runtime.cpp::deserializeCudaEngine::76] Error Code 4: Internal Error (Engine deserialization failed.)
None
File “detect.py”, line 244, in
main(opt)
File “detect.py”, line 239, in main
run(**vars(opt))
File “/home/npci-nx1/.local/lib/python3.6/site-packages/torch/autograd/grad_mode.py”, line 27, in decorate_context
return func(*args, **kwargs)
File “detect.py”, line 79, in run
model = DetectMultiBackend(weights, device=device, dnn=dnn)
File “/home/npci-nx1/best_yolo/yolov5/models/common.py”, line 331, in init
for index in range(model.num_bindings):
AttributeError: ‘NoneType’ object has no attribute ‘num_bindings’
Based on the error log, the engine file is serialized with a different TensorRT version.
Please note that the TensorRT engine is not portable.
You will need to use the same software version and hardware environment to deserialize it.
Please recreate the best_device0_640x480.engine file on XavierNX directly to solve this issue.
