I downloaded libopencv-dev.dep from jetpack 5.1.1 repository to install in docker based on galactic image of dustynv/ros. However, the message says dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Could you try if it can work with --force-overwrite
Actually it did not work.
I have installed opencv library by building from the source and it worked.
Thank you.
