I was trying to install librosa in my newly set up Xavier AGX,
I am getting the following error.
Help me to resolve this issue.
pip install librosa
Defaulting to user installation because normal site-packages is not writeable
Collecting librosa
Using cached librosa-0.8.1-py3-none-any.whl (203 kB)
Collecting numba>=0.43.0
Using cached numba-0.53.1.tar.gz (2.2 MB)
Requirement already satisfied: numpy>=1.15.0 in /home/nvidia-xavier/.local/lib/python3.6/site-packages (from librosa) (1.19.5)
Requirement already satisfied: decorator>=3.0.0 in /home/nvidia-xavier/.local/lib/python3.6/site-packages (from librosa) (5.0.9)
Collecting scipy>=1.0.0
Downloading scipy-1.5.4-cp36-cp36m-manylinux2014_aarch64.whl (24.5 MB)
|████████████████████████████████| 24.5 MB 112 kB/s
Collecting resampy>=0.2.2
Using cached resampy-0.2.2.tar.gz (323 kB)
Requirement already satisfied: joblib>=0.14 in /home/nvidia-xavier/.local/lib/python3.6/site-packages (from librosa) (1.0.1)
Requirement already satisfied: packaging>=20.0 in /home/nvidia-xavier/.local/lib/python3.6/site-packages (from librosa) (21.0)
Requirement already satisfied: audioread>=2.0.0 in /home/nvidia-xavier/.local/lib/python3.6/site-packages (from librosa) (2.1.9)
Requirement already satisfied: pooch>=1.0 in /home/nvidia-xavier/.local/lib/python3.6/site-packages (from librosa) (1.4.0)
Collecting scikit-learn!=0.19.0,>=0.14.0
Downloading scikit_learn-0.24.2-cp36-cp36m-manylinux2014_aarch64.whl (24.0 MB)
|████████████████████████████████| 24.0 MB 465 kB/s
Collecting soundfile>=0.10.2
Using cached SoundFile-0.10.3.post1-py2.py3-none-any.whl (21 kB)
Collecting llvmlite<0.37,>=0.36.0rc1
Using cached llvmlite-0.36.0.tar.gz (126 kB)
Requirement already satisfied: setuptools in /usr/lib/python3/dist-packages (from numba>=0.43.0->librosa) (39.0.1)
Requirement already satisfied: pyparsing>=2.0.2 in /home/nvidia-xavier/.local/lib/python3.6/site-packages (from packaging>=20.0->librosa) (2.4.7)
Requirement already satisfied: requests in /home/nvidia-xavier/.local/lib/python3.6/site-packages (from pooch>=1.0->librosa) (2.25.1)
Requirement already satisfied: appdirs in /home/nvidia-xavier/.local/lib/python3.6/site-packages (from pooch>=1.0->librosa) (1.4.4)
Requirement already satisfied: six>=1.3 in /usr/lib/python3/dist-packages (from resampy>=0.2.2->librosa) (1.11.0)
Collecting threadpoolctl>=2.0.0
Using cached threadpoolctl-2.2.0-py3-none-any.whl (12 kB)
Collecting cffi>=1.0
Downloading cffi-1.14.6-cp36-cp36m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (206 kB)
|████████████████████████████████| 206 kB 454 kB/s
Collecting pycparser
Using cached pycparser-2.20-py2.py3-none-any.whl (112 kB)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /home/nvidia-xavier/.local/lib/python3.6/site-packages (from requests->pooch>=1.0->librosa) (1.26.6)
Requirement already satisfied: certifi>=2017.4.17 in /home/nvidia-xavier/.local/lib/python3.6/site-packages (from requests->pooch>=1.0->librosa) (2021.5.30)
Requirement already satisfied: idna<3,>=2.5 in /home/nvidia-xavier/.local/lib/python3.6/site-packages (from requests->pooch>=1.0->librosa) (2.10)
Requirement already satisfied: chardet<5,>=3.0.2 in /home/nvidia-xavier/.local/lib/python3.6/site-packages (from requests->pooch>=1.0->librosa) (4.0.0)
Building wheels for collected packages: numba, llvmlite, resampy
Building wheel for numba (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-ptd05a5l/numba_a669004ae6f948f094b315d840a2683e/setup.py'"'"'; __file__='"'"'/tmp/pip-install-ptd05a5l/numba_a669004ae6f948f094b315d840a2683e/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-f76bd_xg
cwd: /tmp/pip-install-ptd05a5l/numba_a669004ae6f948f094b315d840a2683e/
Complete output (896 lines):
Using Intel TBB from: /usr
Using OpenMP from: True
running bdist_wheel
running build
got version from file /tmp/pip-install-ptd05a5l/numba_a669004ae6f948f094b315d840a2683e/numba/_version.py {'version': '0.53.1', 'full': '97fe221b3704bd17567b57ea47f4fc6604476cf9'}
running build_py
creating build
creating build/lib.linux-aarch64-3.6
creating build/lib.linux-aarch64-3.6/numba
copying numba/__main__.py -> build/lib.linux-aarch64-3.6/numba
copying numba/extending.py -> build/lib.linux-aarch64-3.6/numba
copying numba/__init__.py -> build/lib.linux-aarch64-3.6/numba
copying numba/runtests.py -> build/lib.linux-aarch64-3.6/numba
copying numba/_version.py -> build/lib.linux-aarch64-3.6/numba
creating build/lib.linux-aarch64-3.6/numba/types
copying numba/types/__init__.py -> build/lib.linux-aarch64-3.6/numba/types
creating build/lib.linux-aarch64-3.6/numba/scripts
copying numba/scripts/__init__.py -> build/lib.linux-aarch64-3.6/numba/scripts
copying numba/scripts/generate_lower_listing.py -> build/lib.linux-aarch64-3.6/numba/scripts
creating build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/enumimpl.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/numbers.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/__init__.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/heapq.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/iterators.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/unicode_support.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/listobj.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/builtins.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/tupleobj.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/setobj.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/hashing.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/mathimpl.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/unicode.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/charseq.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/rangeobj.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/randomimpl.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/printimpl.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/slicing.py -> build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/cmathimpl.py -> build/lib.linux-aarch64-3.6/numba/cpython
creating build/lib.linux-aarch64-3.6/numba/stencils
copying numba/stencils/__init__.py -> build/lib.linux-aarch64-3.6/numba/stencils
copying numba/stencils/stencil.py -> build/lib.linux-aarch64-3.6/numba/stencils
copying numba/stencils/stencilparfor.py -> build/lib.linux-aarch64-3.6/numba/stencils
creating build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_unicode_names.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_struct_ref.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_fancy_indexing.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_errormodels.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_typingerror.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_sys_stdin_assignment.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_tuples.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_sets.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/support.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_obj_lifetime.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/__init__.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_exprs.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_chained_assign.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_init_utils.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_sysinfo.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_tracing.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_builtins.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_ir.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/cffi_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/serialize_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_nested_calls.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_casting.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_enums.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_mandelbrot.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_jit_module.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_record_dtype.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_itanium_mangler.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_datamodel.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_extending.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_unpack_sequence.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_nrt.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_multi3.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_generators.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_debuginfo.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/cache_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_pipeline.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_recarray_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_import.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_gdb.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_locals.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_np_functions.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_listimpl.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_conditions_as_predicates.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_jitmethod.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_exceptions.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/complex_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_alignment.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_try_except.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_cffi.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_jitclasses.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_heapq.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_listobject.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_lists.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_api.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_config.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_optional.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_manipulation.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/orphaned_semaphore_usecase.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_numpyadapt.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_annotations.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_flow_control.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_return_values.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_num_threads.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_typeinfer.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_nan.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_indexing.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/dummy_module.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_parfors.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_typeguard.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_typeof.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_boundscheck.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_sort.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/error_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_blackscholes.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_ir_inlining.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_map_filter_reduce.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/inlining_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_hashing.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dataflow.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_wrapper.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_nrt_refct.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_ir_utils.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_serialize.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_withlifting.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_object_mode.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_svml.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_cfunc.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_stencils.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dictimpl.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_errorhandling.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_conversion.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_range.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_function_type.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_cli.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_slices.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_numpy_support.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_globals.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_comprehension.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_python_int.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_analysis.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_remove_dead.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dispatcher.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/pdlike_usecase.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_caching.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_practical_lowering_issues.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_iteration.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_codegen.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dyn_func.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_mixed_tuple_unroller.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_looplifting.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_complex.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dictobject.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_parfors_passes.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_event.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_ssa.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_interproc.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_llvm_version_check.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_mangling.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_recursion.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_cgutils.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_polynomial.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_auto_constants.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_ctypes.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dummyarray.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/compile_with_pycc.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_attr.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_compiler_lock.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/ctypes_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_asnumbatype.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_support.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dicts.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_funcdesc.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_buffer_protocol.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/annotation_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_moved_modules.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_random.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_fastmath.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_vectorization_type_inference.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_analysis.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_numberctor.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_npdatetime.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_gil.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_constants.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_pycc.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_extending_types.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_print.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_overlap.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_threadsafety.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_maxmin.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_objects.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_vectorization.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_return.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_types.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_help.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_unsafe_intrinsics.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_typedlist.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/threading_backend_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_target_overloadselector.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_ufuncs.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dyn_array.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_byteflow.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_numbers.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_inlining.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_profiler.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_unicode.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_refop_pruning.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_compile_cache.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_copy_propagate.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/parfors_cache_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_mathlib.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_storeslice.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/overload_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_literal_dispatch.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_closure.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_typenames.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/matmul_usecase.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_methods.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_warnings.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_llvm_pass_timings.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_typedobjectutils.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_debug.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_runtests.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_iterators.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_typeconv.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_parfors_caching.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/enum_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_numconv.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_reductions.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_extended_arg.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_make_function_to_jit_function.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_unicode_array.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_func_interface.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_linalg.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_entrypoints.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_func_lifetime.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/recursion_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_operators.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/cfunc_cache_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_deprecations.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_intwidth.py -> build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_parallel_backend.py -> build/lib.linux-aarch64-3.6/numba/tests
creating build/lib.linux-aarch64-3.6/numba/typed
copying numba/typed/__init__.py -> build/lib.linux-aarch64-3.6/numba/typed
copying numba/typed/typeddict.py -> build/lib.linux-aarch64-3.6/numba/typed
copying numba/typed/listobject.py -> build/lib.linux-aarch64-3.6/numba/typed
copying numba/typed/typedlist.py -> build/lib.linux-aarch64-3.6/numba/typed
copying numba/typed/typedobjectutils.py -> build/lib.linux-aarch64-3.6/numba/typed
copying numba/typed/dictobject.py -> build/lib.linux-aarch64-3.6/numba/typed
copying numba/typed/dictimpl.py -> build/lib.linux-aarch64-3.6/numba/typed
creating build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/__init__.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/dispatch.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/vectorizers.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/decorators.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/compiler.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/stubs.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/enums.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/initialize.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/mathdecl.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/codegen.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/mathimpl.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/gcn_occupancy.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/hsaimpl.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/api.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/target.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/hsadecl.py -> build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/descriptor.py -> build/lib.linux-aarch64-3.6/numba/roc
creating build/lib.linux-aarch64-3.6/numba/np
copying numba/np/npdatetime.py -> build/lib.linux-aarch64-3.6/numba/np
copying numba/np/__init__.py -> build/lib.linux-aarch64-3.6/numba/np
copying numba/np/npdatetime_helpers.py -> build/lib.linux-aarch64-3.6/numba/np
copying numba/np/ufunc_db.py -> build/lib.linux-aarch64-3.6/numba/np
copying numba/np/npyimpl.py -> build/lib.linux-aarch64-3.6/numba/np
copying numba/np/arrayobj.py -> build/lib.linux-aarch64-3.6/numba/np
copying numba/np/linalg.py -> build/lib.linux-aarch64-3.6/numba/np
copying numba/np/extensions.py -> build/lib.linux-aarch64-3.6/numba/np
copying numba/np/arraymath.py -> build/lib.linux-aarch64-3.6/numba/np
copying numba/np/numpy_support.py -> build/lib.linux-aarch64-3.6/numba/np
copying numba/np/polynomial.py -> build/lib.linux-aarch64-3.6/numba/np
copying numba/np/npyfuncs.py -> build/lib.linux-aarch64-3.6/numba/np
creating build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/__init__.py -> build/lib.linux-aarch64-3.6/numba/cext
creating build/lib.linux-aarch64-3.6/numba/pycc
copying numba/pycc/__init__.py -> build/lib.linux-aarch64-3.6/numba/pycc
copying numba/pycc/llvm_types.py -> build/lib.linux-aarch64-3.6/numba/pycc
copying numba/pycc/decorators.py -> build/lib.linux-aarch64-3.6/numba/pycc
copying numba/pycc/compiler.py -> build/lib.linux-aarch64-3.6/numba/pycc
copying numba/pycc/cc.py -> build/lib.linux-aarch64-3.6/numba/pycc
copying numba/pycc/platform.py -> build/lib.linux-aarch64-3.6/numba/pycc
creating build/lib.linux-aarch64-3.6/numba/experimental
copying numba/experimental/__init__.py -> build/lib.linux-aarch64-3.6/numba/experimental
copying numba/experimental/function_type.py -> build/lib.linux-aarch64-3.6/numba/experimental
copying numba/experimental/structref.py -> build/lib.linux-aarch64-3.6/numba/experimental
creating build/lib.linux-aarch64-3.6/numba/core
copying numba/core/ir_utils.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/options.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/extending.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/imputils.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/consts.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/__init__.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/lowering.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/funcdesc.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/config.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/utils.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/serialize.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/typeinfer.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/boxing.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/errors.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/withcontexts.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/entrypoints.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/callwrapper.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/decorators.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/inline_closurecall.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/object_mode_passes.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/compiler.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/optional.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/interpreter.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/tracing.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/externals.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/byteflow.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/caching.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/cgutils.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/ir.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/ssa.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/event.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/dataflow.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/typed_passes.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/pythonapi.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/untyped_passes.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/generators.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/bytecode.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/descriptors.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/intrinsics.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/transforms.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/analysis.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/cpu.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/fastmathpass.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/pylowering.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/base.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/environment.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/compiler_lock.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/removerefctpass.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/controlflow.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/debuginfo.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/codegen.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/callconv.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/compiler_machinery.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/dispatcher.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/cpu_options.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/postproc.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/itanium_mangler.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/ccallback.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/sigutils.py -> build/lib.linux-aarch64-3.6/numba/core
copying numba/core/registry.py -> build/lib.linux-aarch64-3.6/numba/core
creating build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/__init__.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/simulator_init.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/random.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/testing.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/errors.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/intrinsic_wrapper.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/nvvmutils.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/vectorizers.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/decorators.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/compiler.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/stubs.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/args.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/types.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/cudamath.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/libdevicedecl.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/initialize.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/libdevicefuncs.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/cuda_paths.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/envvars.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/codegen.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/mathimpl.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/device_init.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/libdeviceimpl.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/dispatcher.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/cudadecl.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/api.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/target.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/printimpl.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/libdevice.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/models.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/cudaimpl.py -> build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/descriptor.py -> build/lib.linux-aarch64-3.6/numba/cuda
creating build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/__init__.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/gdb_hook.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/dummyarray.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/init_utils.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/special.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/dump_style.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/quicksort.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/numba_entry.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/appdirs.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/llvm_pass_timings.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/cffiimpl.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/inspection.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/timsort.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/mergesort.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/literal.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/findlib.py -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/numba_sysinfo.py -> build/lib.linux-aarch64-3.6/numba/misc
creating build/lib.linux-aarch64-3.6/numba/testing
copying numba/testing/__main__.py -> build/lib.linux-aarch64-3.6/numba/testing
copying numba/testing/__init__.py -> build/lib.linux-aarch64-3.6/numba/testing
copying numba/testing/loader.py -> build/lib.linux-aarch64-3.6/numba/testing
copying numba/testing/main.py -> build/lib.linux-aarch64-3.6/numba/testing
copying numba/testing/_runtests.py -> build/lib.linux-aarch64-3.6/numba/testing
copying numba/testing/notebook.py -> build/lib.linux-aarch64-3.6/numba/testing
creating build/lib.linux-aarch64-3.6/numba/parfors
copying numba/parfors/array_analysis.py -> build/lib.linux-aarch64-3.6/numba/parfors
copying numba/parfors/__init__.py -> build/lib.linux-aarch64-3.6/numba/parfors
copying numba/parfors/parfor.py -> build/lib.linux-aarch64-3.6/numba/parfors
copying numba/parfors/parfor_lowering.py -> build/lib.linux-aarch64-3.6/numba/parfors
copying numba/parfors/parfor_lowering_utils.py -> build/lib.linux-aarch64-3.6/numba/parfors
creating build/lib.linux-aarch64-3.6/numba/cpython/unsafe
copying numba/cpython/unsafe/numbers.py -> build/lib.linux-aarch64-3.6/numba/cpython/unsafe
copying numba/cpython/unsafe/__init__.py -> build/lib.linux-aarch64-3.6/numba/cpython/unsafe
copying numba/cpython/unsafe/tuple.py -> build/lib.linux-aarch64-3.6/numba/cpython/unsafe
creating build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/__init__.py -> build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/source_module.py -> build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/setup_setuptools.py -> build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/setup_distutils_nested.py -> build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/setup_distutils.py -> build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/setup_setuptools_nested.py -> build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
creating build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/__init__.py -> build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/cache_usecases.py -> build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_parallel_low_work.py -> build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_parallel_env_variable.py -> build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_caching.py -> build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_dufunc.py -> build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_errors.py -> build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_ufuncbuilding.py -> build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_ufunc.py -> build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_gufunc.py -> build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_parallel_ufunc_issues.py -> build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_vectorize_decor.py -> build/lib.linux-aarch64-3.6/numba/tests/npyufunc
creating build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/__init__.py -> build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_structref_usage.py -> build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_typed_list_usage.py -> build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_literally_usage.py -> build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_examples.py -> build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_jitclass.py -> build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_rec_array.py -> build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_typed_dict_usage.py -> build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_literal_container_usage.py -> build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_llvm_pass_timings.py -> build/lib.linux-aarch64-3.6/numba/tests/doc_examples
creating build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase/nested
copying numba/tests/pycc_distutils_usecase/nested/__init__.py -> build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase/nested
copying numba/tests/pycc_distutils_usecase/nested/source_module.py -> build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase/nested
creating build/lib.linux-aarch64-3.6/numba/roc/hlc
copying numba/roc/hlc/common.py -> build/lib.linux-aarch64-3.6/numba/roc/hlc
copying numba/roc/hlc/__init__.py -> build/lib.linux-aarch64-3.6/numba/roc/hlc
copying numba/roc/hlc/config.py -> build/lib.linux-aarch64-3.6/numba/roc/hlc
copying numba/roc/hlc/libhlc.py -> build/lib.linux-aarch64-3.6/numba/roc/hlc
copying numba/roc/hlc/hlc.py -> build/lib.linux-aarch64-3.6/numba/roc/hlc
creating build/lib.linux-aarch64-3.6/numba/roc/tests
copying numba/roc/tests/__init__.py -> build/lib.linux-aarch64-3.6/numba/roc/tests
creating build/lib.linux-aarch64-3.6/numba/roc/servicelib
copying numba/roc/servicelib/__init__.py -> build/lib.linux-aarch64-3.6/numba/roc/servicelib
copying numba/roc/servicelib/threadlocal.py -> build/lib.linux-aarch64-3.6/numba/roc/servicelib
copying numba/roc/servicelib/service.py -> build/lib.linux-aarch64-3.6/numba/roc/servicelib
creating build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/drvapi.py -> build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/__init__.py -> build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/driver.py -> build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/enums.py -> build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/enums_ext.py -> build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/devices.py -> build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/devicearray.py -> build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/error.py -> build/lib.linux-aarch64-3.6/numba/roc/hsadrv
creating build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/__init__.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_large_code.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_autojit.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_occupancy.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_atomics.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/run_far_branch.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_math.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_intrinsics.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_linkage.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_simple.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_positioning.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_gufuncbuilding.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_decorator.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_reduction.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_memory.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_scan.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_ufuncbuilding.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_compiler.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_async_kernel.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_barrier.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_matmul.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
creating build/lib.linux-aarch64-3.6/numba/roc/tests/hsadrv
copying numba/roc/tests/hsadrv/__init__.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsadrv
copying numba/roc/tests/hsadrv/test_driver.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsadrv
copying numba/roc/tests/hsadrv/test_async.py -> build/lib.linux-aarch64-3.6/numba/roc/tests/hsadrv
creating build/lib.linux-aarch64-3.6/numba/np/unsafe
copying numba/np/unsafe/__init__.py -> build/lib.linux-aarch64-3.6/numba/np/unsafe
copying numba/np/unsafe/ndarray.py -> build/lib.linux-aarch64-3.6/numba/np/unsafe
creating build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/sigparse.py -> build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/__init__.py -> build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/gufunc.py -> build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/decorators.py -> build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/ufuncbuilder.py -> build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/deviceufunc.py -> build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/dufunc.py -> build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/wrappers.py -> build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/array_exprs.py -> build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/parallel.py -> build/lib.linux-aarch64-3.6/numba/np/ufunc
creating build/lib.linux-aarch64-3.6/numba/experimental/jitclass
copying numba/experimental/jitclass/__init__.py -> build/lib.linux-aarch64-3.6/numba/experimental/jitclass
copying numba/experimental/jitclass/boxing.py -> build/lib.linux-aarch64-3.6/numba/experimental/jitclass
copying numba/experimental/jitclass/decorators.py -> build/lib.linux-aarch64-3.6/numba/experimental/jitclass
copying numba/experimental/jitclass/base.py -> build/lib.linux-aarch64-3.6/numba/experimental/jitclass
creating build/lib.linux-aarch64-3.6/numba/core/datamodel
copying numba/core/datamodel/__init__.py -> build/lib.linux-aarch64-3.6/numba/core/datamodel
copying numba/core/datamodel/testing.py -> build/lib.linux-aarch64-3.6/numba/core/datamodel
copying numba/core/datamodel/registry.py -> build/lib.linux-aarch64-3.6/numba/core/datamodel
copying numba/core/datamodel/models.py -> build/lib.linux-aarch64-3.6/numba/core/datamodel
copying numba/core/datamodel/packer.py -> build/lib.linux-aarch64-3.6/numba/core/datamodel
copying numba/core/datamodel/manager.py -> build/lib.linux-aarch64-3.6/numba/core/datamodel
creating build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/common.py -> build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/__init__.py -> build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/misc.py -> build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/iterators.py -> build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/npytypes.py -> build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/abstract.py -> build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/functions.py -> build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/containers.py -> build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/function_type.py -> build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/scalars.py -> build/lib.linux-aarch64-3.6/numba/core/types
creating build/lib.linux-aarch64-3.6/numba/core/unsafe
copying numba/core/unsafe/__init__.py -> build/lib.linux-aarch64-3.6/numba/core/unsafe
copying numba/core/unsafe/refcount.py -> build/lib.linux-aarch64-3.6/numba/core/unsafe
copying numba/core/unsafe/bytes.py -> build/lib.linux-aarch64-3.6/numba/core/unsafe
copying numba/core/unsafe/eh.py -> build/lib.linux-aarch64-3.6/numba/core/unsafe
copying numba/core/unsafe/nrt.py -> build/lib.linux-aarch64-3.6/numba/core/unsafe
creating build/lib.linux-aarch64-3.6/numba/core/typeconv
copying numba/core/typeconv/__init__.py -> build/lib.linux-aarch64-3.6/numba/core/typeconv
copying numba/core/typeconv/typeconv.py -> build/lib.linux-aarch64-3.6/numba/core/typeconv
copying numba/core/typeconv/castgraph.py -> build/lib.linux-aarch64-3.6/numba/core/typeconv
copying numba/core/typeconv/rules.py -> build/lib.linux-aarch64-3.6/numba/core/typeconv
creating build/lib.linux-aarch64-3.6/numba/core/rewrites
copying numba/core/rewrites/__init__.py -> build/lib.linux-aarch64-3.6/numba/core/rewrites
copying numba/core/rewrites/static_getitem.py -> build/lib.linux-aarch64-3.6/numba/core/rewrites
copying numba/core/rewrites/static_raise.py -> build/lib.linux-aarch64-3.6/numba/core/rewrites
copying numba/core/rewrites/static_binop.py -> build/lib.linux-aarch64-3.6/numba/core/rewrites
copying numba/core/rewrites/ir_print.py -> build/lib.linux-aarch64-3.6/numba/core/rewrites
copying numba/core/rewrites/registry.py -> build/lib.linux-aarch64-3.6/numba/core/rewrites
creating build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/npdatetime.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/__init__.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/collections.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/npydecl.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/templates.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/bufproto.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/dictdecl.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/context.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/asnumbatype.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/randomdecl.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/arraydecl.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/builtins.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/cmathdecl.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/setdecl.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/listdecl.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/mathdecl.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/typeof.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/enumdecl.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/ctypes_utils.py -> build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/cffi_utils.py -> build/lib.linux-aarch64-3.6/numba/core/typing
creating build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/__init__.py -> build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/context.py -> build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/nrtdynmod.py -> build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/nrtopt.py -> build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/nrt.py -> build/lib.linux-aarch64-3.6/numba/core/runtime
creating build/lib.linux-aarch64-3.6/numba/core/annotations
copying numba/core/annotations/__init__.py -> build/lib.linux-aarch64-3.6/numba/core/annotations
copying numba/core/annotations/type_annotations.py -> build/lib.linux-aarch64-3.6/numba/core/annotations
copying numba/core/annotations/pretty_annotate.py -> build/lib.linux-aarch64-3.6/numba/core/annotations
creating build/lib.linux-aarch64-3.6/numba/cuda/kernels
copying numba/cuda/kernels/__init__.py -> build/lib.linux-aarch64-3.6/numba/cuda/kernels
copying numba/cuda/kernels/transpose.py -> build/lib.linux-aarch64-3.6/numba/cuda/kernels
copying numba/cuda/kernels/reduction.py -> build/lib.linux-aarch64-3.6/numba/cuda/kernels
creating build/lib.linux-aarch64-3.6/numba/cuda/tests
copying numba/cuda/tests/__init__.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests
creating build/lib.linux-aarch64-3.6/numba/cuda/simulator
copying numba/cuda/simulator/__init__.py -> build/lib.linux-aarch64-3.6/numba/cuda/simulator
copying numba/cuda/simulator/kernel.py -> build/lib.linux-aarch64-3.6/numba/cuda/simulator
copying numba/cuda/simulator/kernelapi.py -> build/lib.linux-aarch64-3.6/numba/cuda/simulator
copying numba/cuda/simulator/compiler.py -> build/lib.linux-aarch64-3.6/numba/cuda/simulator
copying numba/cuda/simulator/reduction.py -> build/lib.linux-aarch64-3.6/numba/cuda/simulator
copying numba/cuda/simulator/api.py -> build/lib.linux-aarch64-3.6/numba/cuda/simulator
creating build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/libs.py -> build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/drvapi.py -> build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/__init__.py -> build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/driver.py -> build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/runtime.py -> build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/enums.py -> build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/rtapi.py -> build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/nvvm.py -> build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/devices.py -> build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/ndarray.py -> build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/devicearray.py -> build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/error.py -> build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
creating build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/__init__.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_casting.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_record_dtype.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_vectorize_scalar_arg.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_inspect.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_debuginfo.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_multiprocessing.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_boolean.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_multigpu.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_userexc.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_vectorize.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_device_func.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_transpose.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_alignment.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_sync.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_atomics.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_array_args.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_freevar.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_exception.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_math.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_array.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_gufunc_scheduling.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_intrinsics.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_blackscholes.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_mandel.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_ipc.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_slicing.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_serialize.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_retrieve_autoconverted_arrays.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_frexp_ldexp.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_nondet.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_operator.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_powi.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_globals.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_cooperative_groups.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_forall.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_lang.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_constmem.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_dispatcher.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_gufunc_scalar.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_cuda_array_interface.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_reduction.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_complex.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_libdevice.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_errors.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_optimization.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_py2_div_issue.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_laplace.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_vectorize_complex.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_compiler.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_random.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_gufunc.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_fastmath.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_localmem.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_vectorize_device.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_print.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_montecarlo.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_multithreads.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_sm.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_complex_kernel.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_cuda_jit_no_types.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_idiv.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_array_methods.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_debug.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_minmax.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_warp_ops.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_matmul.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_datetime.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_vectorize_decor.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_const_string.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_sm_creation.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
creating build/lib.linux-aarch64-3.6/numba/cuda/tests/doc_examples
copying numba/cuda/tests/doc_examples/__init__.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/doc_examples
copying numba/cuda/tests/doc_examples/test_cg.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/doc_examples
copying numba/cuda/tests/doc_examples/test_random.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/doc_examples
creating build/lib.linux-aarch64-3.6/numba/cuda/tests/nocuda
copying numba/cuda/tests/nocuda/__init__.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/nocuda
copying numba/cuda/tests/nocuda/test_nvvm.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/nocuda
copying numba/cuda/tests/nocuda/test_library_lookup.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/nocuda
creating build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_inline_ptx.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_ir_patch.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_cuda_devicerecord.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_select_device.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/__init__.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_cuda_memory.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_deallocations.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_linker.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_context_stack.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_cuda_libraries.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_pinned.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_cuda_auto_context.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_detect.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_streams.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_reset_device.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_cuda_ndarray.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_cuda_driver.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_array_attr.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_managed_alloc.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_events.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_runtime.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_profiler.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_host_alloc.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_emm_plugins.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_cuda_array_slicing.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_nvvm_driver.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
creating build/lib.linux-aarch64-3.6/numba/cuda/tests/cudasim
copying numba/cuda/tests/cudasim/support.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudasim
copying numba/cuda/tests/cudasim/__init__.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudasim
copying numba/cuda/tests/cudasim/test_cudasim_issues.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudasim
creating build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv/data
copying numba/cuda/tests/cudadrv/data/__init__.py -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv/data
creating build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
copying numba/cuda/simulator/cudadrv/libs.py -> build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
copying numba/cuda/simulator/cudadrv/drvapi.py -> build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
copying numba/cuda/simulator/cudadrv/__init__.py -> build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
copying numba/cuda/simulator/cudadrv/driver.py -> build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
copying numba/cuda/simulator/cudadrv/runtime.py -> build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
copying numba/cuda/simulator/cudadrv/nvvm.py -> build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
copying numba/cuda/simulator/cudadrv/devices.py -> build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
copying numba/cuda/simulator/cudadrv/devicearray.py -> build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
creating build/lib.linux-aarch64-3.6/numba/misc/help
copying numba/misc/help/__init__.py -> build/lib.linux-aarch64-3.6/numba/misc/help
copying numba/misc/help/inspector.py -> build/lib.linux-aarch64-3.6/numba/misc/help
copying numba/_npymath_exports.c -> build/lib.linux-aarch64-3.6/numba
copying numba/_lapack.c -> build/lib.linux-aarch64-3.6/numba
copying numba/_typeof.c -> build/lib.linux-aarch64-3.6/numba
copying numba/_dynfuncmod.c -> build/lib.linux-aarch64-3.6/numba
copying numba/mviewbuf.c -> build/lib.linux-aarch64-3.6/numba
copying numba/_dynfunc.c -> build/lib.linux-aarch64-3.6/numba
copying numba/_helperlib.c -> build/lib.linux-aarch64-3.6/numba
copying numba/_random.c -> build/lib.linux-aarch64-3.6/numba
copying numba/_hashtable.c -> build/lib.linux-aarch64-3.6/numba
copying numba/_helpermod.c -> build/lib.linux-aarch64-3.6/numba
copying numba/mathnames.h -> build/lib.linux-aarch64-3.6/numba
copying numba/_arraystruct.h -> build/lib.linux-aarch64-3.6/numba
copying numba/_devicearray.h -> build/lib.linux-aarch64-3.6/numba
copying numba/_pymodule.h -> build/lib.linux-aarch64-3.6/numba
copying numba/_unicodetype_db.h -> build/lib.linux-aarch64-3.6/numba
copying numba/capsulethunk.h -> build/lib.linux-aarch64-3.6/numba
copying numba/_hashtable.h -> build/lib.linux-aarch64-3.6/numba
copying numba/_typeof.h -> build/lib.linux-aarch64-3.6/numba
copying numba/_numba_common.h -> build/lib.linux-aarch64-3.6/numba
copying numba/typed/py.typed -> build/lib.linux-aarch64-3.6/numba/typed
copying numba/cext/listobject.c -> build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/dictobject.c -> build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/utils.c -> build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/cext.h -> build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/listobject.h -> build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/dictobject.h -> build/lib.linux-aarch64-3.6/numba/cext
copying numba/pycc/modulemixin.c -> build/lib.linux-aarch64-3.6/numba/pycc
copying numba/misc/cmdlang.gdb -> build/lib.linux-aarch64-3.6/numba/misc
copying numba/core/runtime/nrt.c -> build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/_nrt_pythonmod.c -> build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/_nrt_python.c -> build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/nrt.h -> build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/nrt_external.h -> build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/annotations/template.html -> build/lib.linux-aarch64-3.6/numba/core/annotations
copying numba/cuda/tests/cudadrv/data/jitlink.ptx -> build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv/data
running build_ext
building 'numba._dynfunc' extension
Warning: Can't read registry to find the necessary compiler setting
Make sure that Python modules winreg, win32api or win32con are installed.
C compiler: aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC
creating build/temp.linux-aarch64-3.6
creating build/temp.linux-aarch64-3.6/numba
compile options: '-I/usr/include/python3.6m -c'
aarch64-linux-gnu-gcc: numba/_dynfuncmod.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/_dynfuncmod.o -o build/lib.linux-aarch64-3.6/numba/_dynfunc.cpython-36m-aarch64-linux-gnu.so
building 'numba._dispatcher' extension
creating build/temp.linux-aarch64-3.6/numba/core
creating build/temp.linux-aarch64-3.6/numba/core/typeconv
compile options: '-I/home/nvidia-xavier/.local/lib/python3.6/site-packages/numpy/core/include -I/usr/include/python3.6m -c'
aarch64-linux-gnu-gcc: numba/_dispatcher.cpp
aarch64-linux-gnu-gcc: numba/_typeof.c
aarch64-linux-gnu-gcc: numba/_hashtable.c
aarch64-linux-gnu-gcc: numba/core/typeconv/typeconv.cpp
aarch64-linux-gnu-g++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/_dispatcher.o build/temp.linux-aarch64-3.6/numba/_typeof.o build/temp.linux-aarch64-3.6/numba/_hashtable.o build/temp.linux-aarch64-3.6/numba/core/typeconv/typeconv.o -L/home/nvidia-xavier/.local/lib/python3.6/site-packages/numpy/core/lib -lnpymath -lm -o build/lib.linux-aarch64-3.6/numba/_dispatcher.cpython-36m-aarch64-linux-gnu.so
building 'numba._helperlib' extension
creating build/temp.linux-aarch64-3.6/numba/cext
aarch64-linux-gnu-gcc: numba/_helpermod.c
aarch64-linux-gnu-gcc: numba/cext/utils.c
aarch64-linux-gnu-gcc: numba/cext/dictobject.c
aarch64-linux-gnu-gcc: numba/cext/listobject.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/_helpermod.o build/temp.linux-aarch64-3.6/numba/cext/utils.o build/temp.linux-aarch64-3.6/numba/cext/dictobject.o build/temp.linux-aarch64-3.6/numba/cext/listobject.o -L/home/nvidia-xavier/.local/lib/python3.6/site-packages/numpy/core/lib -lnpymath -lm -o build/lib.linux-aarch64-3.6/numba/_helperlib.cpython-36m-aarch64-linux-gnu.so
building 'numba.core.typeconv._typeconv' extension
aarch64-linux-gnu-gcc: numba/core/typeconv/_typeconv.cpp
aarch64-linux-gnu-g++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/core/typeconv/typeconv.o build/temp.linux-aarch64-3.6/numba/core/typeconv/_typeconv.o -o build/lib.linux-aarch64-3.6/numba/core/typeconv/_typeconv.cpython-36m-aarch64-linux-gnu.so
building 'numba.np.ufunc._internal' extension
creating build/temp.linux-aarch64-3.6/numba/np
creating build/temp.linux-aarch64-3.6/numba/np/ufunc
aarch64-linux-gnu-gcc: numba/np/ufunc/_internal.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/np/ufunc/_internal.o -L/home/nvidia-xavier/.local/lib/python3.6/site-packages/numpy/core/lib -lnpymath -lm -o build/lib.linux-aarch64-3.6/numba/np/ufunc/_internal.cpython-36m-aarch64-linux-gnu.so
building 'numba.np.ufunc._num_threads' extension
aarch64-linux-gnu-gcc: numba/np/ufunc/_num_threads.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/np/ufunc/_num_threads.o -o build/lib.linux-aarch64-3.6/numba/np/ufunc/_num_threads.cpython-36m-aarch64-linux-gnu.so
building 'numba.mviewbuf' extension
aarch64-linux-gnu-gcc: numba/mviewbuf.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/mviewbuf.o -o build/lib.linux-aarch64-3.6/numba/mviewbuf.cpython-36m-aarch64-linux-gnu.so
building 'numba.core.runtime._nrt_python' extension
creating build/temp.linux-aarch64-3.6/numba/core/runtime
aarch64-linux-gnu-gcc: numba/core/runtime/_nrt_pythonmod.c
aarch64-linux-gnu-gcc: numba/core/runtime/nrt.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/core/runtime/_nrt_pythonmod.o build/temp.linux-aarch64-3.6/numba/core/runtime/nrt.o -L/home/nvidia-xavier/.local/lib/python3.6/site-packages/numpy/core/lib -lnpymath -lm -o build/lib.linux-aarch64-3.6/numba/core/runtime/_nrt_python.cpython-36m-aarch64-linux-gnu.so
building 'numba.experimental.jitclass._box' extension
creating build/temp.linux-aarch64-3.6/numba/experimental
creating build/temp.linux-aarch64-3.6/numba/experimental/jitclass
aarch64-linux-gnu-gcc: numba/experimental/jitclass/_box.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/experimental/jitclass/_box.o -o build/lib.linux-aarch64-3.6/numba/experimental/jitclass/_box.cpython-36m-aarch64-linux-gnu.so
building 'numba.cuda.cudadrv._extras' extension
creating build/temp.linux-aarch64-3.6/numba/cuda
creating build/temp.linux-aarch64-3.6/numba/cuda/cudadrv
compile options: '-Inumba -I/usr/include/python3.6m -c'
aarch64-linux-gnu-gcc: numba/cuda/cudadrv/_extras.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/cuda/cudadrv/_extras.o -o build/lib.linux-aarch64-3.6/numba/cuda/cudadrv/_extras.cpython-36m-aarch64-linux-gnu.so
building 'numba._devicearray' extension
extra options: '-std=c++11'
aarch64-linux-gnu-gcc: numba/_devicearray.cpp
aarch64-linux-gnu-g++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/_devicearray.o -o build/lib.linux-aarch64-3.6/numba/_devicearray.cpython-36m-aarch64-linux-gnu.so
building 'numba.np.ufunc.tbbpool' extension
compile options: '-I/usr/include -I/usr/include/python3.6m -c'
aarch64-linux-gnu-gcc: numba/np/ufunc/tbbpool.cpp
aarch64-linux-gnu-gcc: numba/np/ufunc/gufunc_scheduler.cpp
numba/np/ufunc/tbbpool.cpp:31:2: error: #error "TBB version is too old, 2019 update 5, i.e. TBB_INTERFACE_VERSION >= 11005 required"
numba/np/ufunc/tbbpool.cpp: In constructor ‘fix_tls_observer::fix_tls_observer(tbb::interface7::task_arena&, int)’:
numba/np/ufunc/tbbpool.cpp:87:108: error: no matching function for call to ‘tbb::internal::task_scheduler_observer_v3::task_scheduler_observer_v3(tbb::interface7::task_arena&)’
fix_tls_observer(tbb::task_arena &arena, int mask) : tbb::task_scheduler_observer(arena), mask_val(mask)
In file included from /usr/include/tbb/tbb.h:79:0,
from numba/np/ufunc/tbbpool.cpp:15:
/usr/include/tbb/task_scheduler_observer.h:65:5: note: candidate: tbb::internal::task_scheduler_observer_v3::task_scheduler_observer_v3()
task_scheduler_observer_v3() : my_proxy(NULL) { my_busy_count.store<relaxed>(0); }
/usr/include/tbb/task_scheduler_observer.h:65:5: note: candidate expects 0 arguments, 1 provided
/usr/include/tbb/task_scheduler_observer.h:40:7: note: candidate: constexpr tbb::internal::task_scheduler_observer_v3::task_scheduler_observer_v3(const tbb::internal::task_scheduler_observer_v3&)
class task_scheduler_observer_v3 {
/usr/include/tbb/task_scheduler_observer.h:40:7: note: no known conversion for argument 1 from ‘tbb::interface7::task_arena’ to ‘const tbb::internal::task_scheduler_observer_v3&’
error: Command "aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include -I/usr/include/python3.6m -c numba/np/ufunc/tbbpool.cpp -o build/temp.linux-aarch64-3.6/numba/np/ufunc/tbbpool.o -std=c++11" failed with exit status 1
ERROR: Failed building wheel for numba
Running setup.py clean for numba
Building wheel for llvmlite (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-ptd05a5l/llvmlite_d603d6fb313044e9b9f532b478344e98/setup.py'"'"'; __file__='"'"'/tmp/pip-install-ptd05a5l/llvmlite_d603d6fb313044e9b9f532b478344e98/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-5h14pus5
cwd: /tmp/pip-install-ptd05a5l/llvmlite_d603d6fb313044e9b9f532b478344e98/
Complete output (11 lines):
running bdist_wheel
/usr/bin/python3 /tmp/pip-install-ptd05a5l/llvmlite_d603d6fb313044e9b9f532b478344e98/ffi/build.py
LLVM version... Traceback (most recent call last):
File "/tmp/pip-install-ptd05a5l/llvmlite_d603d6fb313044e9b9f532b478344e98/ffi/build.py", line 220, in <module>
main()
File "/tmp/pip-install-ptd05a5l/llvmlite_d603d6fb313044e9b9f532b478344e98/ffi/build.py", line 210, in main
main_posix('linux', '.so')
File "/tmp/pip-install-ptd05a5l/llvmlite_d603d6fb313044e9b9f532b478344e98/ffi/build.py", line 134, in main_posix
raise RuntimeError(msg) from None
RuntimeError: Could not find a `llvm-config` binary. There are a number of reasons this could occur, please see: https://llvmlite.readthedocs.io/en/latest/admin-guide/install.html#using-pip for help.
error: command '/usr/bin/python3' failed with exit status 1
ERROR: Failed building wheel for llvmlite
Running setup.py clean for llvmlite
Building wheel for resampy (setup.py) ... done
Created wheel for resampy: filename=resampy-0.2.2-py3-none-any.whl size=321048 sha256=794d2fe7e80b4845332ac92117a13ec330e8f4072f267df669bdb2f15be7a230
Stored in directory: /home/nvidia-xavier/.cache/pip/wheels/cf/d4/04/49d8824a42bd9f9b11d502727965b9997f0d41d2b22ae4f645
Successfully built resampy
Failed to build numba llvmlite
Installing collected packages: pycparser, llvmlite, threadpoolctl, scipy, numba, cffi, soundfile, scikit-learn, resampy, librosa
Running setup.py install for llvmlite ... error
command: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-ptd05a5l/llvmlite_d603d6fb313044e9b9f532b478344e98/setup.py'"'"'; __file__='"'"'/tmp/pip-install-ptd05a5l/llvmlite_d603d6fb313044e9b9f532b478344e98/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-phj7a2yy/install-record.txt --single-version-externally-managed --user --prefix= --compile --install-headers /home/nvidia-xavier/.local/include/python3.6m/llvmlite
Complete output (14 lines):
running install
running build
got version from file /tmp/pip-install-ptd05a5l/llvmlite_d603d6fb313044e9b9f532b478344e98/llvmlite/_version.py {'version': '0.36.0', 'full': 'e6bb8d137d922bec8beeb01a237254778759becd'}
running build_ext
main()
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-ptd05a5l/llvmlite_d603d6fb313044e9b9f532b478344e98/setup.py'"'"'; __file__='"'"'/tmp/pip-install-ptd05a5l/llvmlite_d603d6fb313044e9b9f532b478344e98/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-phj7a2yy/install-record.txt --single-version-externally-managed --user --prefix= --compile --install-headers /home/nvidia-xavier/.local/include/python3.6m/llvmlite Check the logs for full command output.
